Forward Cylinders req Longer Pushrods than Rear
Old Feb 16, 2015 | 04:54 AM
Lethalwx69's Avatar
Default Forward Cylinders req Longer Pushrods than Rear
I have a Lq4, fully machined block, that I bought from Summit Racing with 241 heads that were rebuilt. I measure the volume on the cc and they came out to 68cc. The problem I'm having is with my comp cam pushrod length checker the #1 and #8 have a .025in difference. My first measurement on cyl #1 int/exh was 7.375 @ no lash, and the #8 was 7.35 @ no lash. So then I flipped the rocker tray 180deg, now #1 is 7.3875 and #8 is 7.3625. I made sure I was on the base circle of the cam. I have no idea what to do right now.
Old Feb 16, 2015 | 10:26 AM
badazz81z28's Avatar
Are you using checker springs or solid lifters to check? I recall my pushrods not bring exact cylinder to cylinder, but I dont think a .025 difference
Old Feb 16, 2015 | 10:45 AM
gMAG's Avatar
"heads were rebuilt".
Does this mean a valve job? Maybe the seats and valves were ground.
Sometimes, a pit in a valve seat will warrant more correction when grinding.
I have variations in mine. I can't recall the correct figures.
Old Feb 16, 2015 | 10:56 AM
vettenuts's Avatar
Lay a flat edge across all the valve stems, see if you have visible gaps and measure with a feeler gauge. This will give you an idea of how different the valve depths are but can't be used for determining pushrod lengths.
Old Feb 16, 2015 | 02:52 PM
Jontall's Avatar
They ground down the valve stems when they rebuilt the heads instead of using new valves.
Old Feb 16, 2015 | 09:22 PM
Lethalwx69's Avatar
I swapped the driver and passenger side rocker trays, and now all cylinders except the #8 cylinder are with in .006" of each other. I don't know what's up with these rocker trays.
As for the #8 its now there's about a .011" difference. I looked at the receipt for my heads, they had ordered a new int and exh valve. So that explain why #8 requires a shorter pushrod.
Old Feb 17, 2015 | 02:12 AM
Jontall's Avatar
1 new intake and 1 new exhaust valve? Who rebuilt those heads? Buy new lifter trays because there is something wrong with yours; they cost next to nothing.
Old Feb 17, 2015 | 06:28 AM
vettenuts's Avatar
You mean the top of the valve stems? As I recall, they are case hardened and if they ground through them you may find major issues once the car is running. If you mean the valve seat, then they will sit higher relative to the rocker.
Old Feb 17, 2015 | 08:24 AM
Lethalwx69's Avatar
Yes, 1 new intake and 1 new exhaust valve. I had them rebuilt by a shop called Hedahls in Minot, ND. As for those rocker trays I'm definitely buying new ones, mine might be bent or something. I did double check though swapping the trays around makes for uneven pushrod lengths.
Old Feb 17, 2015 | 08:33 AM
Lethalwx69's Avatar
I also screwed up and bought some Comp R 875 lifters without knowing they required adjustable rocker arms. .002 to .004 preload...
Old Feb 17, 2015 | 05:22 PM
Jontall's Avatar
I've seen many guys grind down the valve stems (ends) and it's more common than you think.
Old Feb 17, 2015 | 08:38 PM
miami993c297's Avatar
Seriously?
Old Feb 17, 2015 | 09:58 PM
ls1 1990 VN's Avatar
Originally Posted by miami993c297
Seriously?
Some of mine have been machined down...Lots of guys that are using LS3 hollow valves get them machined down to fit an LS1.
Old Feb 18, 2015 | 05:38 AM
Reassure me, a hardening surface treatment is performed after machining, is that correct?
Christian
Old Feb 18, 2015 | 08:50 AM
Jontall's Avatar
Christian
They are ground using a CNC coolant bath so they never get hot during the process and the hardness is unaffected.
Old Feb 18, 2015 | 09:12 AM
Thank you Jontall for your info on the used process...
Does anyone know if the Rockwell hardness of the valve stem end remain at the same scale as OEM doing so?
Christian
Old Feb 18, 2015 | 03:52 PM
vettenuts's Avatar
Depends on how they were originally hardened. As I recall, the GM valves have a cap welded on the top of the valve.
