Suggestions for cam and intake only?
Current mods are:
Kooks 1 7/8 lt's
Kooks true duals
SLP cold air kit
Bmr tunnel brace, lcas, Panhard bar, strut tower brace, and weld in sfc.
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
http://store.cammotion.com/-named-cams
I do not see why not...they are proven and make power. Sure milder lobes might be the new craze but there is nothing wrong with XER lobes. I doubt anybody is going to reinvent the wheel for the LS1 18yrs later. If I am not mistaken Pat G made 500whp with a SBE LS1 using XER lobes and had no problems controlling the valves. Personally I would prefer a milder lobe for a street car, but the does not mean there is anything wrong with a 228r or Torquer 2.
This!!!!
Moral of the story...there's only so far that cam theory will get you before you have to test it in a real-world environment. A gain on paper may not produce a gain when running in an engine and vice versa.
