another morel lifter preload question
Old Feb 18, 2015 | 09:56 PM
prostock555's Avatar
Default another morel lifter preload question
morel tie bar lifters 5206 what is the max amount of preload you can run safely with a iron block aluminum heads....they recomend .030 1/2 turn but that doesnt seem like that will be enough based on what ive read here on the forms...would .045 be enough thanks in advance...
Old Feb 19, 2015 | 09:05 AM
ss performance's Avatar
I set mine at .050.
I haven't started the engine yet so I don't have any input from driving etc.
Old Feb 19, 2015 | 10:47 AM
thank you the companies recommend one thing, but the real world users are saying different so I believe I will leave it where its at thanks..
Old Feb 19, 2015 | 09:23 PM
miami993c297's Avatar
1/2 turn is the maximum preload I use on Alu/Alu with the 5206...anything above is a lost in power and vacuum...
Christian
Old Feb 19, 2015 | 10:11 PM
are they noisy at 1/2 turn thanks
Old Feb 20, 2015 | 08:55 AM
With my set-up I never noticed any noise difference between 1 full turn, 45', 30' or 15' of a turn...
Old Feb 20, 2015 | 11:41 AM
thanks I will take these pushrods back and get .025 shorter that will put me at 1/2 turn .030..thank you..
