How screwed am I?
These engines are notorious for water seeping in the cylinders through the intake seals and gaskets.
Try the auto trans fluid, I've saved a lot of lifters this way.
Oh and be sure to change the oil before you do anything!
Seafoam doesn't belong in the oil, don't let anyone **** you about it. It doesn't suspend the solids..........................it causes havoc in a dirty engine.
I hope the guy above didn't put any load on the engine while the seacrap was in there. If he did the bearings took some damage I guaranty it. The lifters are noisy because the oil holes are now blocked with solids.
