Forged rod recomendation...
Old Feb 23, 2015 | 11:34 PM
CattleAc's Avatar
Default Forged rod recomendation...
Well it's like Christmas in Feb at my house...
I have a friend that is going with a new "LSX" block for his latest turbo build...he graciously offered me his "used" Manley forged pistons...part# 592539C...
I need a recommendation from you guys on a "budget" friendly forged rod for my build...LQ4, stock crank, previously mentioned pistons...
I've looked a rods on the net for the last week...I have no idea what to go with. I'd like some "real world" feedback on this.
Thanks, in advance.
Old Feb 23, 2015 | 11:54 PM
64post's Avatar
Thanks, in advance.
Assuming you need 6.125" length and .927 wrist pin. (You need to find out) Scat makes a set of 6.125" length, .927" pin, 7/16" ARP bolts with locator dowels, I beams for about $400. I have them in my motor and have whirled to 7 grand a few times and they're still there, is that budget enough? P.S They're lighter than H beams by 50+ grams or so, lighter is better in most cases. You asked.
Old Feb 24, 2015 | 12:01 AM
CattleAc's Avatar
I apologize for not adding more info...and you are correct. those are the specs for these pistons...
6'125" length, .927 pin.
Thanks, I really appreciate the info...this is exactly what I was looking for...
Old Feb 24, 2015 | 05:05 AM
KCS's Avatar
KCS
Moderator
Another vote for the Scat rods. They're really good for the money, probably even overkill in a lot of applications.
Old Feb 24, 2015 | 11:47 AM
JakeFusion's Avatar
Super Hulk Smash
They are $283 shipped from WS6Store... not $400.
http://www.ws6project.com/user_stor/...olts-927-pin-/
Old Feb 24, 2015 | 08:57 PM
CattleAc's Avatar
Thanks man...I really appreciate the input...(I've followed your 376ci Iron Block build since the start).
Thanks for the link Jake...called and talked to them today...
I've followed your "Pulling the trigger on parts" thread from the beginning also.
Old Feb 24, 2015 | 09:33 PM
ScottStaypuff's Avatar
What kind of horsepower and rpm would you guys feel comfortable putting through the $283 Scat rods?
Old Feb 24, 2015 | 10:05 PM
JakeFusion's Avatar
Super Hulk Smash
Personally, I'd feel okay with 7400 RPM and probably 700rwhp. Not necessarily together. However, it includes 7/16 ARP Rod caps, is made of 4340 (even if Chinese) and is a decent budge rod. I probably wouldn't try to put a 370 together an run an F1R with 16psi on it and hope it holds at 900+rwhp.
Ideally, this would be a great replacement rod for a stock stroke setup with forged pistons and a potent heads/cam package with a 200 shot of nitrous. I'd feel okay spinning it to 7 grand or so with the heads/cam+spray.
Stock shortblocks can survive that, this rod would be better than stock by a lot. Especially in a blueprinted shortblock.
Hope it helped out man!
Old Feb 24, 2015 | 10:07 PM
A.R. Shale Targa's Avatar
I run them in 450-550 flywheel horse stock car engines that make 60 plus dyno pulls to 7200 each and every Saturday night. As long as the pistons are lighter than old TRW stuff and the crank is a decently balanced forging; they will last.
Old Feb 25, 2015 | 02:29 AM
Jontall's Avatar
That's a great price for rods.
Old Feb 26, 2015 | 02:53 PM
CattleAc's Avatar
Ok, I have one more question...I can get the same rods with the ARP "2000" series bolts for and extra $96.00. $379.00. The rods with the ARP "8740" bolts are $283.00...
Is this even a consideration for this rod at an extra hundred bucks...???
Is the "2000" series the way to go???
Old Feb 26, 2015 | 03:07 PM
KCS's Avatar
KCS
Moderator
With a 7/16" diameter bolt, I think the 8740 material would be fine for just about any hydraulic roller application. When you get down to the smaller diameters, like 3/8" or the stock 9mm, that's when I like to step up to the ARP 2000 material.
Old Feb 26, 2015 | 05:20 PM
JakeFusion's Avatar
Super Hulk Smash
Yeah, I wouldn't worry at this point about the 8740 vs 2000.
In fact, I've been thinking about restalling my converter and running forged pistons and these rods in my 346 and spraying 250 through the motor. I've already spent the money on a good heads/cam package for a 346 and have the rest of the car setup to handle it. So I see no reason not to just use nitrous to go faster and these rods seem fine to me.
Old Feb 26, 2015 | 05:32 PM
CattleAc's Avatar
Alright fella's, thanks...be some 8740 equipped Scat's on the way here tomorrow.
Old Feb 26, 2015 | 09:21 PM
n20transam's Avatar
Not sure if you measured everything, but doesn't the 6.0 block have a shorter deck? Pretty sure you're gonna be .010 out the hole If you run the 6.125 rod. I've done that before, but you need to make sure you get the rest of the stuff right with your heads and head gaskets for your chosen compression and quench.
Old Feb 26, 2015 | 11:47 PM
CattleAc's Avatar
I think the deck height on all LS based engines is 9.240"...???
These came out of a 6.0L turbo motor that ran 6.125" rods...I'll double check all measurements/specs...but I think I'll be ok.
Old Feb 27, 2015 | 07:39 AM
n20transam's Avatar
You will be ok. I was just letting you know they'll be out of the hole a little and you're prob going to have to run a .050-.060 thick head gasket so that your quench won't be too tight.
The 6.0 blocks are a 9.230 deck height
Old Feb 27, 2015 | 10:58 PM
64post's Avatar
Just giving him an example, $283, all the better.
http://www.ebay.com/itm/like/230805437015?lpid=82&chn=ps
Old Feb 28, 2015 | 09:38 AM
Rise of the Phoenix's Avatar
Good thread. So your buddy just gave you those pistons? If so, good friend. How much do those pistons run new?
Old Feb 28, 2015 | 11:31 AM
CattleAc's Avatar
Thanks 64post, I going to use exactly what you suggested, I appreciate the input.
Funny story about the pistons...I met this guy at a car show...he has a bitchin' Mazda RX7 turbo Ls conversion. (He's a member on here, rotary1307cc) I go over and chat him up...(this is a typical "Midwest" car show, tons of muscle cars...ricers not so much)
To me, his car stood out head and shoulders above anything there as far as technology and H.P. went...anyway, I bugged him about his combo for over an hour, I explain how bitchin' I think his ride is and that I'm a cheap *** and try to do everything on a "low-buck, no-buck" approach...he makes a lot of his own parts, so he's of the same mind set...
Anyway...long story long...we go our separate ways. This was July. About Dec I see on here in his thread...https://ls1tech.com/forums/conversio...70-tc78-2.html he's updating to the "LSX" block...I PM him about any left over parts...he gets right back and says I can have the pistons. I offer to pay...he says no, "I know you'll put them to good use, Merry Christmas".
Yeah...I haven't found these for under $600.00 yet...
I'll make it right with him someday...when I figure out how...
__________________
