Cam and Crank Dot question,???
Old Feb 25, 2015 | 09:26 AM
LoneSStar's Avatar
Default Cam and Crank Dot question,???
So im in the process , of installing tsp 233/239 cam in my 02 ls1 ss... ive been reading ls1 how to for this but also had some questions... i bought springs,pushrods,lifters and the trunion upgrade,and ls2 timing chain.. my question was ,since i dont have adjustable timing chain no need to degree the cam..? just make dam sure to have the cam and crank dots lined up right.. ? crank at 12oclock,cam at six o clock.. ? just really dont wanna mess this up... ive done old school sbc and bbc cam swaps but this is my first ls swap and wanna make sure everthing goes smoothly...any input is greatly appreciated!!!!
LoneSStar's Avatar
this is on stock 241's and stock gaskets by the way..
Old Feb 26, 2015 | 07:05 PM
Doug Hampton's Avatar
I'm in the middle of the same process and that sounds like what I found when I took it apart, what I read and what I have done going back together. Probably wont have it all the way together until tomorrow night or Saturday morning!
Fingers crossed!
Doug
Old Feb 26, 2015 | 07:14 PM
KCS's Avatar
KCS
Moderator
Degreeing the cam is a good thing to do, regardless of the timing set. It's like checking bearing clearance or PTV.
Old Feb 26, 2015 | 07:36 PM
93Z2871805's Avatar
Veteran: Air Force
Yes, 6 o'clock for the cam, 12 o'clock on the crank. Make sure you verify PTV clearance. You CAN degree it without an adjustable timing set, you would just use an offset bushing to change timing. Personally, I would just install it dot-to-dot and let it eat.
Old Feb 26, 2015 | 09:13 PM
jmargo's Avatar
The correct way to do it is to degree the cam especially on a cam that hasn't been spun on the cam doctor. With that I would guess 90% of the instals are done dot to dot.
Old Feb 28, 2015 | 09:46 PM
gMAG's Avatar
When the dots are aligned, (crank @ 12, cam @ 6,), the number 6 cylinder is at TDC.
Number 1 is TDC when the crank is @ 12, and the cam is at 12.
Most people don't know this, and it only occurs this way on the LS series, as far as I know.
You can prove this to yourself by rotating the assembly while watching the opening and closing of valves.
Old Mar 1, 2015 | 12:04 PM
svede1212's Avatar
Technically TDC is just that, when the piston is at the top. You're describing TDC for firing in the dot-to-dot position of #1 and #6 both at the top but #6 is in the firing phase. They are both TDC also when both dots are up but then the phases are reversed.
The main reason for degreeing is to make sure the cam is ground correctly. They sometime aren't as well as chain stretch, etc.
Old Mar 1, 2015 | 12:25 PM
01ssreda4's Avatar
TDC is CRANK at 12 o clock, period. It has nothing to do with the cam in any way shape or form. There are two times the crank and cam are "aligned" (12 and 12 or 12 and 6). TDC on compression, and TDC exhaust. Whether it's compression or exhaust is determined by cam position. 6 or 12 o clock. So, crank at 12, cam at 6 OR 12 and you're money. Remember the cam turns half speed so a full rotation of the crank take the cam half, so you're always coming from or going to 12 and 12 or 12 and 6.
Old Mar 1, 2015 | 04:43 PM
gMAG's Avatar
Yes, I am aware of this...but the OP may not be.
Old Mar 1, 2015 | 04:52 PM
01ssreda4's Avatar
Its just some terms get so loosely thrown around that it starts getting confusing for the newer folks. Sometimes we just half to clarify and get it all out in the open.
