Tick SNS Stage 2 or 3?
I have no surging what so ever, even when the stock 10 bolt was in it
That said, I would not recommend the SNS Stage 3 for a DD.
Only unless you have already owned previously cammed LS engines with MS3/4, T-rex, Vindicator, Polluter sized camshafts before and understand the nuances that go with a cam of this size.
Although a 4000 converter can "take advantage" of a larger cam and possibly be quicker at the drag strip, it still comes down to how the car is used.
We see more converters come back because they were too aggressive than the other way around. If you cruise the car a ton on the street, that stall WILL become annoying.
