advise on coolant pipes
Old Mar 6, 2015 | 03:08 PM
bigdan1's Avatar
Default advise on coolant pipes
2004 LQ4 with "241 " LS1 heads & LS6 intake ,,,,
The original 2001 LS1 ( W/LS6 intake ) had one coolant pipe at the front and two plugs at the back
The LQ4 has two coolant pipes ( front & back )
should I use two pipes or reinstall the back plugs ? ( 241 heads on LQ4 )
thanks ,
Dan
Old Mar 6, 2015 | 03:21 PM
Darth_V8r's Avatar
Moderator
If you can get everything to go together, use the two pipes.
