ls1 rocker torque spec with double springs
Old Mar 13, 2015 | 07:08 PM
LoneSStar's Avatar
Default ls1 rocker torque spec with double springs
Hey bros, can anyone tell me what the torque spec would be with 650. Lift double springs,... ?? Just want to make sure before I button everything up on the cam, swap.. (stock 241 heads, stock 346 ls1 block).. thanks guys ...
Mike
Old Mar 13, 2015 | 09:16 PM
Zmg00camaross's Avatar
Same as factory 22 ft lbs.
Old Mar 13, 2015 | 09:29 PM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Yes indeed!
Old Mar 14, 2015 | 07:28 AM
vettenuts's Avatar
Here is the GM procedure, same for your setup as stated above.
Old Mar 14, 2015 | 07:33 AM
LoneSStar's Avatar
Great, thanks guys!..much appreciated!
Old Mar 14, 2015 | 09:21 AM
tta656's Avatar
Good Info
