using comp cams valve stem seal installer ?
Old Mar 14, 2015 | 08:13 PM
jerr6's Avatar
Default using comp cams valve stem seal installer ?
has anybody use this before? it seems like it ruins the springs on the seals. had to remove the spring first then it works good.
i reused some of the old springs to replace the 3 i ruined. good idea or bad?
Old Mar 14, 2015 | 09:18 PM
99Bluz28's Avatar
Imo, you're either using the wrong seal installer, or somehow you're doing it wrong.
I'd buy more seals , and plan on replacing any with old springs on them. If you have to reuse some of the old seal spring temporarily write down which seals you used old seal springs on for future reference when you replace them with new seals, again.
If you're using Comp Cams #5334 then you're definitely doing it wrong.
Old Mar 14, 2015 | 09:38 PM
jerr6's Avatar
Yes I'm using 5334. Seems like a no brainer to use. Guess I'm wrong. Just a couple taps to get them seated. Seals went on smoothly just messed the spring up. Idk what I could be doing wrong
Seems like the part that holds the spring on the seal doesn't fit into the tool
Old Mar 15, 2015 | 02:53 AM
Jontall's Avatar
There is a problem with it so use a 12mm socket. https://ls1tech.com/forums/generatio...-unseated.html
Old Mar 15, 2015 | 07:43 AM
01ssreda4's Avatar
I have the kent moore version. Its a cool little ******. Can get on ebay for about $10.
Old Mar 15, 2015 | 09:47 AM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
I too use a 12mm 12pt, but I'd like to see this Kent Moore tool. Have a part number?
Old Mar 18, 2015 | 10:04 AM
01ssreda4's Avatar
http://m.ebay.com/itm/271708318781?nav=SEARCH
Old Mar 18, 2015 | 10:05 AM
01ssreda4's Avatar
I may have errored in the 10 bucks but I know I didnt pay that much.
Old Mar 18, 2015 | 02:17 PM
MuhThugga's Avatar
12mm, 12pt socket works like a champ.
