How high to butterfly?
Speedtigger posted a piston to valve calculator for Excel. Search this forum for it and plug in the cam numbers you are considering.
http://store.cammotion.com/the-titan1
It will have great midrange torque and pull strong to 6200-6500 in your 5.3 with ported heads. This cam will also be very easy on the valve train. Cam Motion is known for this. Just order some good hardened pushrods and matching valve springs.
Just because Cam Motion is grinding some of my cams doesn't mean that if you order from them that you are getting an "EPS" Camshaft. The process of me providing specifications for a specific combination and my lobe design belongs to me and me alone. If you want to get a 'clone', that is fine, but keep in mind that the end result won't necessarily be the same.
All without taking a toll on the valve train.
Engpwrsys.com
