LQ9 Cam ??
Old Mar 19, 2015 | 06:25 PM
redneckram2005's Avatar
Default LQ9 Cam ??
What is the largest lift you can put in a stock lq9 without cutting the pistons with stock 317 heads?
Old Mar 19, 2015 | 06:36 PM
96capricemgr's Avatar
EVERY time a question similar to this is asked the answer is lift has little to do with it because the cam is nowhere near peak lift when the piston is near TDC. Look around for similar threads, someone posted a calculator that will get you close.
Valve event timing is what causes PTV conflicts.
