Cathedral Port Vs. Rectangular Port
However, they were only introduced in 08 and it's taken the aftermarket a few years to get them right. I think as we move forward, you'll see them putting out much higher flow numbers that start to separate them from the much more mature cathedral head products. Cathedrals still have a place. Say you want a 600HP motor - the cathedral provides much more torque and airspeed with the smaller, more optimized port.
But also, if you don't take advantage of the head, then you can't make use of it's strengths. A cam with only .450 lift doesn't take advantage of the cathedrals either. Does that mean the cathedral is worse than a SBC 23 degree head which might have a smaller port but similar flow in the .200 and .300 range? Of course not. And while the LSx platform has a larger cam core which allows better lobe design to add stability to the valvetrain, it's all part of making advances to make more and more power. Look at the LT series... Or things like the Low Lash Solid Roller... .700" lifts are easy and effective on street motors.
Progress. Progress. Progress.
Now that you brought up low lash solid roller and .700" lift. Something came to my mind while you said that. Is it possible to run a solid roller on the street without having to adjust the valve lash like a HYD roller cam? Also what is the highest lift cam can one run without having valve spring problems? THANKS!
I say if you do the low lash solid roller, you can do tall Proform valve covers with relocated coils and it would be easy to pull the cover and do a quick check every time you change your oil.
I would be comfortable running .700" lift on the street. If the heads don't stall out at .700 or just past it, you could even run a .750 or so. After that, you get into much more expensive valve spring options. The 1209s from PAC are good to .750 and are no more expensive than the 1207s which are good to 700. And work well with those cams.
Thanks for the INFO. Now I learn something.
Frankenstein TFS 237s
Frankenstein TFS LS3 255s
Frankenstein Ported Stage 2 LS3 OE Heads
Cheapest is the OE heads.
But all will support 416 to 7500. No problem. And all will make more than 600. Talk to Chris Frank. He'll probably say his Stage 2 heads would be tough to beat. But may sway you to the Cathedral ports. The LS3s flow so much more air, but it doesn't manifest as additional power.
If you're trying to pass off a 440 incher with a "money maker" kit as a 346 NA with cathedrals, it helps to remove all signs of awesomeness. Rusty E-Bay headers will help too....Lol
If you're trying to pass off a 440 incher with a "money maker" kit as a 346 NA with cathedrals, it helps to remove all signs of awesomeness. Rusty E-Bay headers will help to....LOL
If your feeling real ambitious you can machine a hole in the end pads for the OEM freeze plugs for total stealth!
I love an innocent looking deal that runs hard.....its great seeing the faces of the guys you just beat!
www.mamomotorsports.com
Tony@MamoMotorsports.com
Anything worth doing is worth doing well. Build it right the first time....its alot cheaper than building it twice!!
take a closer at a rectangle port head, you will see the intake rocker arms have an offset to account for the pushrods being relocated.
And just for comparison:
235/251 cam in both cases personally here:
FRH - 554/490 whp
PRC 265's - 583/526 whp
On a 150 shot:
FRH - 700/620whp
PRC's - 753/771whp
So, yes I'm not a big proponent of FRH's work, especially for the money. I spent just over 1/2 for PRC's work on my stockers and as you see the results speak for themselves.
