Knock sensor seal breaking when installing valley cover
Old Mar 23, 2015 | 10:55 PM
toeffer777's Avatar
Default Knock sensor seal breaking when installing valley cover
I am assuming I am having this problem because of something I'm doing wrong, but I don't know what. When I am putting the valley cover on, the seals are breaking the lip off trying to go over the bosses in the block.
Any advice?
Old Mar 23, 2015 | 11:01 PM
rennat_2006's Avatar
Lube them up. Never had a problem doing it that way, even reused a set this way.
Old Mar 23, 2015 | 11:09 PM
toeffer777's Avatar
Yeah i lubed them up with motor oil before installing. Still broke them.
Old Mar 23, 2015 | 11:22 PM
Installing them in the valley cover then installing the vc to the engine or installing the vc then putting the seals into it and over the ks bosses at the same time?
I grease them up, wheel bearing grease is fine, install them into the vc then install the vc on the engine making sure to push it straight down onto the ks bosses.
Old Mar 23, 2015 | 11:24 PM
toeffer777's Avatar
I installed them on the vc then installed the vc on the engine
Do the flat sides go down, i hope so, thats how im doing it.
Old Mar 24, 2015 | 08:37 AM
Darth_V8r's Avatar
Moderator
I used silicone grease from Napa - no issues. Can't remember which side was down - too long ago.
Old Mar 24, 2015 | 09:14 PM
toeffer777's Avatar
Well crap, I guess ill just get 6 of them and hope I can make two work.
