Lq4 Potential Build. 2 cents needed
Goals: 4-500 NA, & 550-600 with spray Into a Rx7 FC or 240sx
(Note: all used parts will be inspected & cleaned the correct way)
Craigslist LQ4
Granny speed shop/Sikky/Hinson Swap kits pending car selection(not picky)
TH400 MVB W/ Transbrake ( cant justify spending $2800 for t56 & another 2000 to build it up)
370 C.U
Engine internals: (looking at TSP for purchases)
Stock Crank
Connecting rods: TSP 6.125 H beam with 2000arp
Pistons- Wiseco 4.03 +12CC Dome ( to increase compression )
Clevite P main bearings
Balancing done by TSP
Wrist pins- standard ( unless they are the ones that come with stock motors)
* Reluctor wheel, i have no clue on whether i need 24x/58x.
*Heads I'm naturally lost*
But as of now ive read 243 heads W/ ls6 Intake is where its at. Subject to change ( also heard milled lq4 heads arent half bad )
Cam: looking at the MS3 or Hot cams
headers, intake, exhaust , injectors & pump will be done before this motor is ran but have not gotten far enough to pick the parts.
any advice, improvements, Whines, Bitches, moans & gropes.
Thanks
Just remember the better your heads are the smaller the cam you can run and make killer power.
Here is a link to what I'd do personally. Notice they mention 450-500 rwhp and it's within your BUDGET.
http://www.advancedinduction.com/LSX/AiLSx232ccGMLS2Head.php
And if its reliable enough hell ill daily drive the beast... As far as cams go, this will be my first v8, and what would a v8 be without the soundtrack. Which ever one can aid my goal and be nitrous friendly. Coming from the honda scene & the V6 camaro (shamefully the 2013 LFX shitty motor) i dont know much of cam specs or flow ratings of heads... YET.
I sit on my duty post and just research in and out so eventually ill get around to the inns and outs of cams in perspective to long term goals.
You're going to need some SERIOUS valvetrain to handle 10k. Be prepared to spend 3-5x as much on such a setup vs. one that only revs to 7500.
I feel that 450-600 well keep me honest for quite some time, and i also assume the streets of northern Cali wont be packed full of solid contenders so i will have my reign for the most part lol
thanks for answering that question btw
http://www.advancedinduction.com/LSX...cGMLS2Head.php
thanks =]
Far as tranny the ONLY thing I would consider a TH400 for is pure dragracing and even then I probably wouldn't use it in a light car.
500fwhp and you will be able to keep it under 6500rpm and for that I wouldn't touch the shortblock, just buy one in decent shape from a junkyard.
What are your thoughts on stall and gear?
So baby step, TSP/wiseco. Look deeper into heads see if i can find some extra pocket $$ to go for aftermarket heads.. im in no rush, but i only want to do this once.
hell i'm not even set on a hp figure, what i Want and what i'm content with are far between. 5 to wheels will be alot for me especially in a lighter car.
