Lq4 Potential Build. 2 cents needed
Old Mar 24, 2015 | 06:37 PM
gotz02skate's Avatar
i like the idea of manual. hate the idea of forking over 3-5 grand. tranny>built>new fly>new clutch
so if im mistaken a th400 (priced at 1500) rated at 700trq with transbrake and a mvb is only going to rob me of power? (assuming i get the correct and adequate converter with it??)
Old Mar 24, 2015 | 07:01 PM
96capricemgr's Avatar
Is this plan pure drag or a street/strip car?
Old Mar 24, 2015 | 07:38 PM
Taxman20's Avatar
Yes. You can get other tranys to handle the same power for the same money. And they weigh less and take less hp to turn. You could build a th350 to handle your power. We used powerglides in our drag cars but you want a street car with more than 2 gears. Maybe look into a 700r4. I know lots of cars running them with good power and no problems.
Old Mar 25, 2015 | 02:23 AM
Plans are for a weekend warrior street car that, if i love enough will daily.
so off a quickie search
700r4 in the 240 or rx7 didn't come up with many hits. (odd shaped looking tranny imo)
checked out the 350 im not opposed to it but i think some fabb'n may be required.. think i'm going to take the less stressful route and get the t56 built and done with.. seems like the simpler more basic route.
Old Mar 25, 2015 | 02:51 AM
Lawhead's Avatar
Just curious if you're aware on how much compression you will have with them pistons and 243s? It'll be north of 14:1
And with the manual and automatic thing its really not that much more, Unless you plan on putting a cheap converter in the car by the time you get a cooler, Tranny, Converter, Build on the tranny.
Old Mar 25, 2015 | 06:55 AM
Taxman20's Avatar
I didnt think about fit. You will find something. Good luck with the build.
Old Mar 25, 2015 | 07:58 AM
No clue law, looks like i got alot more research to do. But i do thank everyone that has posted here and pointed me in the right direction .
Old Mar 25, 2015 | 08:36 AM
Lawhead's Avatar
Running the same with my LS3s which have bigger chambers and I'll be in the 14:1 range
