hotcam experts please?
Seems like an affordable cam to install on a weekend here soon...not looking for big power gains..just something to give it some grunt on the weekends when I'm able to drive it..
Rather than spend the money on a hot cam, an new timing chain and oil pump would be a better way to spend funds while it is apart.
i know enough not to use the stock springs (from all the research) but knowing the max lift it just fine for this cam, stumps me on why they ARENT such a good idea?
heres my best bet for the cam. and then order some ls6 springs
again, not looking for much of a power gain, just breaking the virgin ls1 experience. ive had plenty of work with sbc/pushrod engines, but then again, not rushing, so getting some advice from all of you wont hurt a bit, thanks
It looks like SDPC is $10 cheaper than JEGS on the kit you need. You can reuse your stock pushrods with the hot cam. If you've worked on SBCs, I think you'll appreciate some of the stuff GM has done with the LS1 in terms of overall design (especially when it comes to setting valve lash). Read up on how to install a cam in one of these motors and you'll be fine.
If I had to do it again, I would have replaced the knock sensores and oil pressure sending unit at the same time. Had to go back and get them done later.
