LM7 to Hybrid LSx?
Hey everyone. Going through the process of building an LM7 which I plan on putting in a 240SX. I just had a few questions before jumping onto more parts while the block and heads are at the machine shop.
1 - LS7 Coils are different then LS1 coils from what I'm reading, though from some of the diagrams I've found for the harness wiring they don't look too different. As long as I get the coil pack harness for the LS7 (which I believe is GM part #12601824) I should be fine correct? They shouldn't have issues with a Gen III ECU? I know someone's going to recommend truck coils, but sadly I can't run them. In the process of collecting parts for this engine I ended up getting Holley Valve covers to reduce the engine clutter and the damn things sadly don't line up with valve cover mount points.
2 - Serpentine systems right now are throwing me for a loop. I've been lurking the F/S threads here and some other forums but cannot find a newer F-body set of brackets up for sale. I've been looking around on different sites and cannot find any vendors selling complete refurbs/new/used sets anywhere so I've had to branch out. Upon hunting around I found a kit on Jegs and Summit for the CTS-V that are complete (minus the water pump and harmonic balancer) but they claim they don't work with iron blocks. I'm not sure, nor can I get anyone to confirm if that comment is for the iron LSX crate engines or for any LS style iron block. I'm staying away from the Corvette style to keep everything tight to the engine, also have hopes to find a way to get a sidemount supercharger setup to work with it.
Any input would be great!
That wasn't hard to find. Took 2 minutes on ebay.
LS1 LS6 Corvette Front Accessory Serpentine Belt Drive Brackets Pulleys New | eBay
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
For further comments, please see this thread as I've moved most of my comments there since this is more of a hybrid engine topic:
https://ls1tech.com/forums/conversio...mix-match.html
