Oil pressure problem
Looking for a little help here!! I recently built a LQ4 for a project 91 Chevy pickup and when i started the engine it was carrying 45psi oil pressure hot until i hooked the PCV system up wrong and it built crazy vacuum in the crank case and lost oil pressure. I replaced the oil filter thinking maybe it collapsed it internally and oil pressure came back. Then tried reconfiguring PCV system and did the same thing. But now I can not get oil pressure back. Is there ant chance it could have sucked the o-ring out of the pickup?
