Finished my build today!!
X
Tinker
Car is now traction limited! Definitely needs a new tires...down to the wear bars. I am absolutely destroying the 315/35/17 Toyo TQ DR's. Tried a couple launches and can not go past half throttle in first and second gear spins until 65-70mph.
Raced my Dads 85 Monte SS. It has a LPE built (as cast)Dart Headed SBC 383 with a 230/236 110, built 2004r and a FTI 3200. Billet Specialty 15x10's with a 275-60-15 MT DR. Power is in the 500hp range at the crank.
From a dig we both spun but I was able to roll out on him and pull 4-5 cars to 100mph.
We did a couple 10 and 20 rolls with me pulling 2-2.5 cars to 100mph.
I had my wideband hooked up and noticed the afr was in the 13.8-14.0 range @ wot. The crazy thing was the motor was not pulling any timing running that lean.
So when we got back from running, I added 10% to my VE to get the car to hit it's target PE vs EQ of 12.6:1. Well after that the car picked up a significant amount and traction became much worse.
So I decided to put the car on the lift and measure the suspension geometry and evidently lowering the car threw the rear end alignment off some. I wondered why the car was wanting to go left. So I adjusted my LCA's and now the car is going straight. Still need to measure pinion angle, but traction seems a little better now.
Might get the car on the rollers in July.
Went with a new wheel setup. 17x4.5 & 15x10 Dark Stars with a 275-50-15 MT DR
Went out this evening to the spot where I always run, hooked up my Gtech and went 11.69 first pass on 3/4 tank of gas. Came out of hole half throttle then put it to the floor, stuck good. Then a few rain clouds came through and I did not try again. I am guessing 11.3's will be doable on the street with this combo. Pretty decent for the street imo.
