What is safe to use to clean a cylinder wall?
I am about to finish cleaning the LS1 shortblock I recently bought and want to know the safest and best way to clean this one cylinder. This is the only cylinder that has a few spots of either light carbon build up or light rust. What do you guys recommend that would work without damaging the cylinder wall?
It will also get the moisture out of the cylinder and help eliminate rust
Finish with some fresh oil coating the walls
Don't use assembly lube in the cylinder walls or piston top
