Time to change my C1 cam??
Old Mar 14, 2003 | 05:23 PM
NastySSoo's Avatar
Default Time to change my C1 cam??
Do you guys think a bigger cam would be worth it for me? I have MTI stageIIs with the C1 cam. The car runs very well and makes good power. Its a daily driver and does very well with this set up. What cam would give me a legidimate power increase, and still be streetable with A/C and such. The car gets a LOT of track time so a power increase would be nice. Any suggestions??BTW, the car is an M6 with the 112 C1. Thanks in advance!
Old Mar 14, 2003 | 05:30 PM
RedlineLS1's Avatar
Default Re: Time to change my C1 cam??
You might want to try a C2 cam. Its a little bigger and still very streetable for an everyday car. You would look to gain a little off of it.
Old Mar 14, 2003 | 05:44 PM
NastySSoo's Avatar
Thanks for your input. I thought about that but wasnt sure if the difference would be worthwhile. Im thinking something a little more aggressive! Any other suggestions?? <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Mar 14, 2003 | 11:47 PM
MechMan's Avatar
X1 ???? <img border="0" title="" alt="[Razz]" src="gr_images/icons/tongue.gif" />
Itll be runnin Tues. <img border="0" alt="[driving]" title="" src="graemlins/gr_driving3.gif" />
Old Mar 15, 2003 | 01:07 AM
wicked 98z's Avatar
I dont think the c2 would be worth the swap. You might want to look into something bigger like the X1 or the TR 230. If you want to go wilder get the g5x2 <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Mar 15, 2003 | 04:34 AM
Street Racer's Avatar
Paul are your heads milled any ? Forget a new cam through a damn gear in it those 3.73 are not killing you but if you had 4.30's im sure it would be running 11.3's <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" /> good luck on your search Paul <img border="0" alt="[driving]" title="" src="graemlins/gr_driving3.gif" />
Old Mar 15, 2003 | 07:26 AM
NastySSoo's Avatar
X1 , Hmmmmm! Yeah Mike, my heads are milled 30 thou. I would like a little more gear, but I hate to spend the $$ on that right now. With the gears I also have to send the computer out again.I wonder what difference I would see with the X1??? <img border="0" alt="[burn out]" title="" src="graemlins/gr_burnout.gif" />
Old Mar 15, 2003 | 08:12 AM
if you get the gears we could do them at my house to save ya a little $$$ <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> Have you moved the battery to the back yet ? Plus we could do some light weight carpet in that beast as all. Let me know I will help you out with what ever you need. Sorry to get off subject....
T T T
Old Mar 15, 2003 | 08:59 AM
BLUEBALLS ZZ's Avatar
whats the deal nastyss00. you already broke my e.t <img border="0" title="" alt="[Razz]" src="gr_images/icons/tongue.gif" /> now you want more. just spray the bitch!! <img border="0" alt="[evil]" title="" src="graemlins/gr_devil.gif" /> the x1 feels good in mechs car and he is going to put those heads on. the heads have 1/2 more compression. MTI says it is fine. but with the x1, the lift is big. you may have to change the springs. the 230 230 i don't think you have to worry about the springs. think the lift is in the 570 area. both cams you will need to shift up there to get the maximum potential out of them. and streetracer is right. you are going to need gears for those cams to really wake up your car. but you can always do that at a later time. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
<small>[ March 15, 2003, 09:01 AM: Message edited by: BLUEBALLS ZZ ]</small>
Old Mar 15, 2003 | 09:03 AM
Brian98's Avatar
nastyss--
what size pushrods r u using..
Lenght.....7.35's?
Brian
Old Mar 15, 2003 | 11:08 AM
Raughammer's Avatar
D(irecto)r Pepper
The C1 is capable of 10.8's in the right set up.
Are you sure you have maxed out your present combo to take full advantage of the current cam before going and spending money on parts that you have already spend money on?
Just something to think about.
The C2 is worth a bit more hp...as is the X1 and so on and so on.
But there are ALWAYS trade offs.
Racing is a compromise...if you add here... you lose a bit there.
Just some things to ponder....before you slap down your hard earned cash.
Old Mar 15, 2003 | 04:33 PM
NastySSoo's Avatar
Thanks guys, I appreciate all the input. I have MTI stage II heads with their stock lengh push rods. I shimmed the rockers as Roughammer suggested. The car has gone a best of 11.55@ 118.15 on an et street. Raceweight is 3610 with me in it. 60 ' was 1.65. Its best mph is 118.80. My mph seems a little low compared to some M6s but maybe it is the weight?The car runs very well and I am very happy with it. The suspention is basically stock with only LCAs. But my 60fts seem about as good as most at the cars weight.I really dont want to give up any low end grunt for more topend. Im just hearing so much about these new cams. I do feel my heads will support a bigger cam though. Street racer, thanks for your offers dude, your a good bro, as are Mechman and Blueballz!! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Mar 15, 2003 | 04:38 PM
MechMan's Avatar
Here's some pretty cheap 4:30's
https://ls1tech.com/ubb/ultimatebb.p...c;f=7;t=011224
Wait till you drive pops car with them. They arent to bad at all.
<small>[ March 15, 2003, 04:40 PM: Message edited by: MechMan ]</small>
Old Mar 19, 2003 | 08:34 AM
no kidding. but you got to remmeber NastySS00 is pushing more power then pops. might just take a while to get use to. pop's car ain't normal nither. runing 12.20's with just bolt on's and 7000 miles on it ain't normal <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> can't wait to see what how those 4.30's will do for him <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
