head bolt help ?
Old Apr 10, 2015 | 09:43 PM
speed750's Avatar
Default head bolt help ?
I have a 97 LS1 that I'm putting 243 heads on, any suggestions for a reasonable head bolt solution? Don't want to run stock head bolts ($50) and don't want to spend $180 for early LS1 ARP bolts. Is there a mid range solution?
Old Apr 10, 2015 | 10:37 PM
99 Blue Bird's Avatar
EBay studs
Old Apr 11, 2015 | 08:19 PM
squalor's Avatar
https://ls1tech.com/forums/generatio...ngth-test.html
Maybe this link will help with your decision.
Old Apr 11, 2015 | 09:50 PM
kinglt-1's Avatar
ARP can be had for less then 180.00.
Old Apr 12, 2015 | 05:45 PM
.boB's Avatar
You get what you pay for (if you're lucky). Pro-comp/chinese/speedway79/whatever-it is-this-week junk ends up being way too expensive. I wouldn't use them if they were free.
Use the stock GM and don't worry about them. Or pony up for the ARP, and don't worry about them.
