LQ9 head gaskets?
4.00 Bore
3.62 Stroke
71cc Head combustion chamber
0 Dome or dish... LQ9 has flat top piston
.051 Head gasket thickness on LS9's
4.10 Head gasket bore on LS9's
.008 deck hight.
http://www.wallaceracing.com/cr_test2.php
So you can run the LS9 gaskets on your motor with out dropping the compression much at all. Stock LQ9 compression is 10:1. If you don't think forced induction will happen I would go with a .040 cometic and bump the compression up a bit.
4.00 Bore
3.62 Stroke
.008 deck hight.
