throw out the ls6 intake?
Old Apr 21, 2015 | 07:46 PM
fbody4everyone's Avatar
Originally Posted by redbird555
I would do the fast and headers at the same time to save on tuning costs. Go with 1-7/8 headers. They will always gain over 1.75 and lose nothing down low. Dont believe everything you read by people on here.
Sounds great. Is a new maf needed with the intake setup?
Old Apr 21, 2015 | 08:03 PM
redbird555's Avatar
I would lol the 74mm will be a restriction. For a mild cam a z06/truck maf will be fine. They are called 85mm but are really 90 i.d
Old Apr 21, 2015 | 08:18 PM
Sounds good. I'll be ordering my list soon. Now just to find a tuner around Iowa ... Wish me luck lol
Old Apr 21, 2015 | 08:32 PM
02WSsicks's Avatar
Not to be that guy, but I put down 420 rwhp with a LS6 intake, home ported (really just cleaned up) 799 heads, and my screened tiny stock 1998 MAF, combined with an "old" TR 230/224 grind through 1 7/8" headers. Just saying Power is in the combination of parts, and in my opinion air speed right up to before going sonic. I think the LS6 intake starts to find its limit around 265CFM. And remember air flow in an engine is not linear, but rather pulses. There is a point where a head and intake will "back up". Air speed and volume gets tricky.
Old Apr 21, 2015 | 08:45 PM
redbird555's Avatar
Your combo made really good power with an ls6 intake, that doesnt mean though it wouldnt have made more through a fast. I made 425 with my setup below and an ls6 intake with completely stock 243's after the FAST and a couple touch ups it made 448.
Heads will always be the next best upgrade over a cam and the combo matters very much so. But a FAST will still gain him. The ls6 is choking the motor with a small cam and 243's no doubt.
Old Apr 21, 2015 | 09:00 PM
My setup will include, fast tb/intake with maf, hotcam, and headers..... 241s tho. Hopefully they aren't too restrictive compared to 243s.
I will probably do mail order tune by Frost..? Hp numbers will go up a tad with tune correct ?
Old Apr 22, 2015 | 04:11 AM
scotty2000ss's Avatar
Haven't seen anyone mention this to the OP, but make sure you DO NOT buy a FAST TB. Nick Williams is superior to the FAST.I have a Fast 92 and the tune has never been spot on.
Old Apr 25, 2015 | 10:06 PM
Fast intake causes tune to be off? Which one in particular? I've never came across someone saying that
Old Apr 25, 2015 | 10:09 PM
Fast throttle body, not the intake.
Old Apr 25, 2015 | 10:13 PM
redbird555's Avatar
Yep lol any time you make a significant change to the air going in or out of the engine you need a tune. The fast intake will be sucking in so much more air than now it will throw the maf calibration out, also if you get a bigger maf that has to be calibrated to your car as well even if you didnt change the intake. Headers also need a tune due to relocating the o2's and changing the exhaust flow. Long story short do all the mods at once and then get a tune
Old Apr 29, 2015 | 03:15 PM
I wasn't planning on getting tune until everything was ordered. 243 heads, 1 7/8 headers, intake manifold, and ... maybe fast tb? confused on what the problem is with that considering tuning issues?
Old Apr 29, 2015 | 03:36 PM
  #32
If you buy a fast tb and have an aftermarket cam you'll find out. Ask the person tuning your car. He should be able to answer that question if he's experienced.
Old Apr 29, 2015 | 04:45 PM
  #33
So what would the preference for a tb be then if FAST is out of the question?
Old Apr 29, 2015 | 05:41 PM
  #34
http://www.ws6project.com/user_stor/...throttle-body/
I would recommend this. I'm using a fast 92 TB now and am having nothing but problems. I bored out the iac hols more tonight. Going to start it up no . Wish me luck lol.
Old Apr 29, 2015 | 05:46 PM
  #35
Damn sorry to hear that lol good luck. But why would you recommend it if you have one and having issues man!?
Old Apr 29, 2015 | 05:55 PM
  #36
I didn't. I recommended the Nick Williams throttle body. Re read my post.
Old Apr 29, 2015 | 06:01 PM
  #37
Oh, I thought you meant you had that tb, my bad. What's the difference in the 2?
Old Apr 29, 2015 | 06:07 PM
  #38
This link should clear it up lol.
https://ls1tech.com/forums/pcm-diagn...pics-info.html
