Attention Cam Guys
Mods are slp lid, 3.73 gears, ported throttle body, slp cat-back exhaust, and long tube headers
TSP has a list of $200 cams for sale and I called and they recommended the 239/243 .651/.654 112.
This cam seems very big to me and im worried that power wont come on until 5500 rpm. This is the second smallest cam so I looked at the smallest next.
TSP has the 220/248 .581/.615 116 that is the smallest cam on the list but I am again worried about it being a complete slug before 4500 rpm
This list can be found here https://ls1tech.com/forums/sponsor-s...ters-more.html
The last cam I considered is an Slp cam with SKU: SKU: SLP-51014. Advertised specs are 236/236 .590/.590 112. This cam is about $300 at http://www.lethalperformance.com/slp...FSxn7AodlAcALw
Any expertise on these cams or recommendations would be awesome!
pretty much any cam you look at is going to need springs.
if you can't afford springs, you could look at some drop-in cam options, but those cams will be around 350.
To do a cam and springs, you need to set aside a minimum $700. you have water pump gaskets, front cover gasket, coolant, front main seal, timing set (not recommended to put old timing set on new cam), a valve spring compressor tool (cheap autozone or napa tools wont work), and you'll want to do an oil change a few hundred miles later. then figure another 300-400 for a good tune to get the most out of the cam.
Only thing I don't really like as far as your build is that you running 3.73 gears. Kinda a waste imo.... install 4.10s and you'll be smiling all over again. Also I noticed you said you have lost some races.... well the truth is you might be shifting each gear each race at a different rpm. Invest in a shift light. You'll be surprised how much faster your car will feel shifting more consistently.
If you want a cam that will drive ok and make good power in the mid-upper rpm range keep overlap to around 8 degrees max 0-8 will all be a good choice. Overlap is calculated by (intake duration+exhaust duration)/2-(2*lsa) so a 239/243 on a 112 has 17 degrees overlap..... This cam is going to be a dog with a stock ls1 until 3500 where it will turn on and rip but its def a top end cam and street manners will not be good along with low end being terrible.
With that in mind here are a couple cams I found in the classifieds thats will fit your needs better.
https://ls1tech.com/forums/parts-cla...nout-sale.html
https://ls1tech.com/forums/parts-cla...4-113-lsa.html specs on this one are 231/239 112lsa so 9 degrees overlap (close enough to 8).
at the end of this thread MRCLEAN says he has a 229/234 so i would pm him and see whats its all about. This one and the TV2 I thin are your best options.
https://ls1tech.com/forums/parts-wan...d-new-cam.html
I understand not wanting to blow 400 on a cam BUT the extra 200 is well worth it than to get a cam that is all wrong for your intended uses. Just something to think about. A cam swap isnt cheap, after the cam you will have another 200 in springs, 40 in a timing chain, 100 in an oil pump, 100 in pushrods and then figure another 100 for coolant, oil and misc gaskets. Then you need a dyno tune which is usually around 450.
Those are all things that MUST be done with no corners cut or you will pay the price.
There is a thread on here where Tony Mamo got close to 490 RWHP on ported 862 truck heads with a cam that is WAY smaller than you'd think for that kind of power
On a side note, what mods were done to the SRT-4. Stock for stock the SS will walk it all day.
The problem is people are over complicating a motor thats 18 years old.. keep it simple. Your wants in how you want your car to perform has been asked years ago and everyday.
Keep it simple.. i would not go any smaller than a 228/228 cam from TSP. If you wanted a bit more cam, look into a TSP torquer 2 232/234 or a speed inc SI5 231/237.
Those are good choices with endless results..
My first cam was the old X1 230/227... drove great. Never experienced any other cam. My current cam is a 233/239. Drives just as smooth.
SNS Stage 2
Standard Lobes: 227/235 | .61x"/.62x" | LSA110+3
Milder Lobes: 226/234 | .60x"/.61x" | LSA110+3
And for the guys that think big cams only make peak power, in some cases you are correct, but it's not true for everyone. I will attach my dyno sheets so you can see what the SNS Stage 3 looks like. The first pic is of my old setup with a 228/230 cam, same heads as now, and LS6 intake. The next pic is my current setup. There were a few other small changes as well going to the new setup, so please don't get caught up in the numbers/cams thing. The purpose of posting this is just to show the difference between smaller and larger cams and how the power behaves on the dyno. Notice the larger cam made more power throughout the pull.
