how weak are these bolts?
195k
How much of a pain is it to take exhaust manifold bolts out without breaking them? Putting new headers on and my lovely instructor says I will FOR SURE break them. But as far as I'm concerned, I've proved him wrong enough.. How about I listen to ls1tech crew and succeed again? Lol
..is it a decent deal or certain procedure to easing them off?
Thanks
soak them like Darth_V8r said. Before trying to break one free, put a short (3") extension against the bolt head and give the extension a smack with a metal hammer. Light smack, more than a tap.
When you go to take them out if they feel like they are getting stiff, stop and reverse the direction of the bolt slowly working them all out. Are you ready to buy headers yet?
Bolt busting is my fear on this part lol
For 1-7/8 headers you have about 4 choices. Tsp and Speed engineering both make them in stainless and are the best budget options. Both fit great the speed eng ones are 379.99 WITH a y pipe the tsp ones are 539.99 with a y pipe. The tsp may be a little better quality but its marginal. The speed eng ones are on backorder till sometime in May though so you wont get them for a while. The Tsp's are in stock.
If you want the best of the best 1-7/8 then look at Kooks or ARH which is what I run but be prepared to spend 700-800 for just the headers
Headers really arent bad to install, just get the car up high enough. You also want to do poly motor mounts while youre there. They're cheap and even if you dont think you need them, you need them lol
It doesn't take much force to break them. I got all but one out on my truck and the last one broke. In fact that last bolt broke with less force on it than it took to break the others loose so I had no way of knowing it was going to happen. I even snapped both bolts on my muffler.
Second on the PB Blaster. It helps a lot.
I'll soak the bolts pretty good before hand then, seems to be the ideal choice. & what happens if I break one or.. 5? Head removal and bring to shop?
I think I'd be more into getting new heads to skip the headache lollol
What's your take on that?
Another warning from experience on the cheap headers - the two bolt holes in the middle don't always line up perfectly with the bolt holes in the head. If it happens, it'll be one or the other that will want to cross thread. If that happens, take off the header
and make that hole a bit bigger or else live with an exhaust leak ticking all the time.Also, like redbird said, get the car up high. Too high is almost high enough
