High RPM issues
Old May 1, 2015 | 04:39 PM
BlackSS2001's Avatar
Default High RPM issues
Anything over 4k RPM and it starts backfiring and falling on its face. Sometimes the tach just stops working after a bad backfire. I have noticed also when holding the RPM's around 4500+ the tach will bounce around a little randomly. It doesn't matter if I'm at WOT or just holding the RPM's up there.
I have changed the Cam position sensor (doesn't mean it isn't a faulty one)..
Thinking about changing the Crankshaft position sensor next and doing a relearn on it.
Fuel pressure is good, injectors are good and the spark plugs all look good.
I'm also wondering if a knock sensor could be causing some of the issue..
Old May 1, 2015 | 05:08 PM
9sectruck's Avatar
Check crank and cam signal,, sorry seen cam sensor changed.... look at a scanner and see if the crank is losing signal
Old May 1, 2015 | 05:32 PM
KCS's Avatar
KCS
Moderator
I've seen a couple cars now doing something similar and it turned out to be the reluctor wheel.
Old May 2, 2015 | 05:28 PM
Russ K's Avatar
Check for excessive crankshaft end play.
Russ Kemp
