PTV double check...
Old May 2, 2015 | 09:35 PM
CarlostheBarbarian's Avatar
Default PTV double check...
Whats up guys,
Long story short is I was lazy and had my H/C set up installed by a friend of a friend who turned out to be a hack and is no longer in business...made it 2500mi and my ATI balancer backed off into my steering rack(2004 z06). As I pulled stuff apart I found oil leaks and other half ***'ness(loose bolts etc.)
Anyway I yanked the heads and I'd appreciate it if anybody could tell me if my PTV check method was on par...
1. Installed lifters/trays
2. Stock MLS .051 head gasket
3. Snugged head on with two bolts(#1 cylinder)
4. Using check springs...installed rockers to zero lash
5. Turned engine over 3 times and back to TDC on #1
Using clay....intake .071 and exhaust .115
Heads are RHS 225's(2.05"/1.60") 62cc
Comp cam 232/240 .608/.595 112 XER lobes
Its my first go around doing this with an LSx...appreciate any feedback including if I screwed it all up. Thanks in advance
Old May 2, 2015 | 11:28 PM
blk00ss's Avatar
Looks good to me. Rock it.
Old May 3, 2015 | 05:59 AM
EDS01SS's Avatar
Exhaust clearance looks great but that intake clearance is not enough. .100 is the minimum clearance to look for according to every cam manufacturer that I have seen. Personally I like to use a ls7 lifter that I have modified with washer inside to make it solid even with the check springs and I also will measure more then once
Old May 3, 2015 | 07:27 AM
poltergeist 02's Avatar
I have always seen .080" intake and .100 exhaust. If your measurements are correct, I would run it. Remember, the intake valve chases the piston down. I would be a little more concerned if it was the exhaust valve that was that tight. What did you use for a gasket when you snugged the head up for measuring?
Old May 3, 2015 | 12:17 PM
Yeah, I've been told and heard the same. The motor has ran with this set up already and I used the old GM MLS head gaskets that were in it. It's tighter than I'd like on the intake but i've ran into the 6800rpm limiter more than I should admit with those numbers.
The guy who put it together never checked PTV. Truth be told with the 2.05" valve I thought it was going to be tighter.
Thanks guys
