Which cam
Old May 8, 2015 | 07:56 AM
kinglt-1's Avatar
It will sound like any other 228/232 more then likely. Those 2 cams installed and set up correctly are probably more alike then different.
Old May 8, 2015 | 09:05 AM
mac62989's Avatar
Originally Posted by whatsa347
Na not on the SS HT, already asked him. His reasoning is that he has had zero failures with them. He uses lunati cores and I've heard of zero failures on the forums, and you know as well as I do if there had been one, someone would have immediately posted it and complained.
I stand corrected, cant believe everything you read.. Thats a bummer though because that made the choice super easy for me
Old May 8, 2015 | 10:26 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Originally Posted by alexcoreas
I'd like to how much a package deal would cost?
PRC 2.5 heads and cam package and everything to complete an install. I'm almost ready just waiting to get my car back from the paint shop
The 2.5 5.3 heads and cam kit is 1909.99 with PRC .650 double springs. A gasket and bolt install kit for an Ls1 is 159.99 with GM bolts, or we can upgrade to ARP for a little more.
https://texas-speed.com/p-4346-preci...-outright.aspx
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old May 8, 2015 | 12:07 PM
whatsa347's Avatar
Red face
You and me both, but its still reassuring to know I've never seen an FTI cam go flat. I'd buy his cam in 100% confidence.
Old May 8, 2015 | 04:29 PM
mac62989's Avatar
Ya I agree I haven't either which is reassuring. For years I was always debating between the SS HT and the cam 01SSREDA4 has that spartan always recommended but once I read CAMMOTION was grinding some cams for Ed it seemed too perfect.
Old May 8, 2015 | 05:40 PM
01ssreda4's Avatar
Absolutely correct, josh at Spartan performance highly recommended the older shelf grind of the what it now titan4. He used it a ton of times in builds just didnt mention (***** it out) on here often so it was overlooked.
Old May 8, 2015 | 06:29 PM
JTtransAM's Avatar
If you don't mind me asking, what heads did you use and what numbers were you putting down?
Old May 8, 2015 | 06:46 PM
mac62989's Avatar
Ya I remember the threads he did post. He made 400+rwhp many times cam only
Old May 8, 2015 | 06:53 PM
01ssreda4's Avatar
I have the AI 226cc 799s milled 40. No dyno numbers, being an auto and all it doesn't interest me much. It ran 11.2x @ 118 last go round. Its gonna go faster this year without going into the motor I can tell you that much.
Old May 8, 2015 | 07:49 PM
JTtransAM's Avatar
Yeah that's a pretty impressive time regardless. I'm just trying to narrow down my choices on heads for the Titan 4 to estimate total costs. I'm assuming that cam requires dual Springs since that's all that cam motion sells.
Old May 8, 2015 | 09:11 PM
01ssreda4's Avatar
I would put a dual spring on it just to be precautionary. If you really wanna know the limits ask Kip the owner of cam motion for his spring recommendation. Obviously he knows his cams better then anyone.
Old May 8, 2015 | 09:46 PM
  #32
whatsa347's Avatar
Contact EPS as well, ground through cam motion also. You can also apparently now get EPS cams on any duration as well according to kip.
Old Aug 14, 2015 | 02:50 AM
  #33
SSEUL8R's Avatar
I'm sure the OP already has made his choice on cams, but for what it's worth to you guys, I just bought a Streetsweeper HT from Ed. He emailed and told me it's coming from Comp Cams and will be on a Callies core. It's supposed to be here Monday the 17th, I'm at a 'work stoppage' waiting on the cam. I heard somewhere that Ed used Lunati, then I heard on this thread that Ed used Cammotion, but the cam that I got from him is from Comp Cams. I'm guessing their whole cam whining thing is behind them or he wouldn't be using them.
Old Aug 16, 2015 | 03:47 PM
  #34
JTtransAM's Avatar
I'll be going with the Titan IV. I'm just rethinking my head selection now...
Old Aug 16, 2015 | 04:27 PM
  #35
Darth_V8r's Avatar
Moderator
that's a good choice. It'll drive good and make lots of power. What are you thinking head wise? Aim for around 11-1 to get the most out of it
Old Aug 26, 2015 | 11:21 PM
  #36
JTtransAM's Avatar
http://www.advancedinduction.com/LSX/AiLSx223ccDartHead.php
I've been looking into the AI 223 dart/ rhs heads. I'm on somewhat of a budget otherwise the MMS 220's would be my choice hands down.
Old Aug 27, 2015 | 09:41 AM
  #37
Darth_V8r's Avatar
Moderator
The head that I seem to see the most positive reviews on after the MMS220 is the TFS 220 as cast. It'll be $200 more than the AI linked above, but a 2.055 intake valve vs 2.000.
In all honesty, though heads at this level are varying degrees of awesome, though I'm very partial to the Mamo220.
