junk or usable?
Old May 9, 2015 | 12:30 PM
98Zeric's Avatar
Default junk or usable?
I picked up a lq4 from a 01 3/4ton. I knew there was 2 rods that broke but figured I take a chance.. I was hoping there wouldn't be any damage to the lower part of the cylinder. . I wasn't so lucky. The damage doesn't look to bad. But before I take it to the machine shop..am I wasting my time? does anyone else have experience with simular issue?
Old May 9, 2015 | 12:33 PM
springer_4's Avatar
    Old May 9, 2015 | 01:11 PM
    Majestic9C1's Avatar
    its garbage
    Old May 9, 2015 | 02:41 PM
    98Zeric's Avatar
    Ya.. That was my thought.. just hoped I was wrong haha
    Old May 9, 2015 | 03:54 PM
    .boB's Avatar
    Why junk? The damage is below the rings. Why can;t you grind out that damaged area and use it? Cylinders are cut like that for strokers.
    I'm not an LS expert, that's why I ask.
    Old May 9, 2015 | 04:02 PM
    98Zeric's Avatar
    .boB has a great point..thats what i was hoping for and why i asked .
    Old May 9, 2015 | 10:41 PM
    CattleAc's Avatar
    Can you tell if it's into the water???
    I'd get the cam and the crank out before I made a final judgment...
    Old May 10, 2015 | 08:31 AM
    98Zeric's Avatar
    From what i could see, the damage looked like it just in the small area.I'll finish taking it apart and look it over better. Maybe get some better pictures
    Old May 10, 2015 | 01:49 PM
    98Zeric's Avatar
    Old May 10, 2015 | 01:54 PM
    96capricemgr's Avatar
    A stroker might be machined at the base of the cylinder to provide clearance but that is a different operation than debris smashing around and potentially cracking beyond the missing material, like possibly to water.
    I would want more thorough inspection, carefully grind it smooth and magnaflux, or pressure test, something............
    Old May 10, 2015 | 02:09 PM
    98Zeric's Avatar
    I agree. I think at least I'll have them megnaflux the area.. maybe in the meantime I'll come across a good deal on a bare block
    Old May 10, 2015 | 02:22 PM
    dans2000camaross's Avatar
    Default new guy with oil psi issues
    hi guys! as the name states my name is Dan and i have a 2000 camaro SS. anyways i have a bit of a issue.
    ok so my car. it has a LS1 that i have done some work to. she has 243 heads with otherwise stock valvetrain. stock lifters pushrods and rockers. she also has a fast 92mm intake with throttle body. volant cai, hooker LT headers with catted y pipe. borla cat back with cutout.
    the issue is low oil pressure, changed the pump to a mellings 295. still getting 10psi at idle. took pump back out and shimmed the spring(3 washers) and still getting 17-20 psi hot idle. cold idle she gets 55-65 psi. going down the freeway she gets 45-50 at 70mph. im running mobil 1 10w30 with a quart of lucas...stp filter. car has a 160 degree thermostat....what gives? also tried 2 different oil pressure sending units. 1 from autozone, one from advanced.
