Lq4 with 243 heads
Old May 11, 2015 | 03:44 PM
69blackwidow's Avatar
Default Lq4 with 243 heads
Ok this is what i am looking at,I have an Lq4,found a pretty good deal on some ready to bolt on 243 heads and and the same guy has a 228R 112lsa from texas speed. cam is new in its box. not looking to drag race or anything, its going into my 67 chevelle convert as a driver. any input on this mike
Old May 11, 2015 | 03:58 PM
JRENIGAR's Avatar
Should make a nice 10.1:1 or so driver with a nice chop to it. Id maybe mill the heads .030" and use a cometic .040" thick gasket to help bump it up a bit more if budget allows. Probably gonna need a 3200-3600 stall with it.
Old May 11, 2015 | 04:21 PM
I did read that about the stall on the texas speed page. thanks for the input. do you think 10.5:1 with the mill and the gasket
Old May 11, 2015 | 04:33 PM
windmill's Avatar
using the 40 thou gasket and milling 30 off mine was lie 10.9 and I still run 93 pump gas . the the motor in my mustang,, its in sig
Old May 11, 2015 | 04:51 PM
Would just doing the 40 gasket do anything. i have no clue about this stuff, kicking the tires for now
Old May 11, 2015 | 06:36 PM
do you guys think that is to much cam for a stock 05 Lq4 with 243 heads (228R 112lsa) going to have a 4l60 and 355 or 373 rear
Old May 11, 2015 | 06:46 PM
Darth_V8r's Avatar
Moderator
That sounds like a nice, fun build. Motor will run great. If you want to save a bit of coin, use the .041" head gasket and don't mill. You'll end up around 10.5:1. With that 228R cam, you'll want 3.73 gears behind the auto trans.
For the record, I don't think that is too much cam at all. That's a good choice for the 243 heads and 4" bore. You will probably need 36# injectors with that set up. You'll want long tube headers to work well with that cam. Intake, a Fast 92/92 would be plenty.
Old May 11, 2015 | 07:14 PM
Thanks for your input Darth, take`in lots of notes lol
Old May 11, 2015 | 07:40 PM
98Zeric's Avatar
69blackwidow any work done to the 243's?.. what intake you planning on using?
Old May 12, 2015 | 04:24 AM
95wannabe's Avatar
Did you buy these local on CL?
The ones originally from Diablo racing?
If so, you may want to check with him. The Ad said they had been "surfaced"
Old May 12, 2015 | 06:46 AM
He said the 243`s were surfaced. and yes wannabe
Old May 12, 2015 | 06:48 AM
allmotor1's Avatar
Sounds solid to me.
Old May 12, 2015 | 04:53 PM
windmill's Avatar
oh forgot,, I didn't have to fly cut pistons, for my cam
Old May 12, 2015 | 05:15 PM
Just got home from picking up parts, congrats to Allen and wife with their first baby. great guy to talk to and gave me a great deal on the parts. He said the 243 heads were off a vette with the good light weight valves, the cam is the texas speed 228r new still in the bag, texas speed push rods new in bag and a set of GM head gaskets. wish i had the money to buy the lower half of him. baby steps lol
Old May 13, 2015 | 03:14 PM
pdsq98gt's Avatar
I have the exact same setup in my BMW. I drive it daily with a 4l60e and a yank ss3200 converter. 3.91 gears. It has great torque and pulls to 6500 no problem. I also am still on stock 28lb injectors. But they are maxed out. It's fairly tame and have no problem drivability wise. I even drive it in the snow. Solid combo.
Old May 13, 2015 | 10:50 PM
pdaq98gt what intake are you running and valve springs
Old May 14, 2015 | 08:27 AM
pdsq98gt's Avatar
Ls6 intake and the beehive PRC 1518 springs that come with the TSP 228r cam package.
Old May 14, 2015 | 09:11 AM
98Zeric's Avatar
Pdsq98gt do you have any work done on the 243's?.. what kind of power curve does your combo put out?
Old May 14, 2015 | 01:07 PM
pdsq98gt's Avatar
No. Stock 243s off of a 5.3. I haven't dynoed the car so I can't really say. But there is a ton of torque. I don't think the 3200 converter and 3.91 gears hurt either though. I am thinking of having AI CNC port the heads and get a bigger cam just because I can't leave well enough alone. I do get 18mpg avg per tank and that's turning 2600 at 70.
Old May 14, 2015 | 07:36 PM
98Zeric's Avatar
Either of you(69blackwidow,pdsq98gt) thought about l92/ls3 top end swap?
