Some extra HP if possible
Old May 17, 2015 | 06:28 AM
mullahi's Avatar
Default Some extra HP if possible
Hi guys I have a 99 Camaro z28 swapped to LQ9 with 243heads + cammed , piston upgrade and crank, ls7 lifters, LS6 intake manifold and shooting 300HP with a plate wet system. the car pretty got nice numbers but I was thinking of couple ideas to increase the HP by changing the nitrous system to 8 fogger as long as I have extra space of praying according to the turner and its safer in my opinion.
what do you guys think.
Old May 17, 2015 | 06:51 AM
Tuskyz28's Avatar
stock bottom end ? I wouldn't recommend running a 300 shot on a stock bottom end..... maybe a smaller shot.
Also not sure what your cam specs are but some cams work better that others when spraying nitrous especially with a large Shot.
Old May 17, 2015 | 07:52 AM
HCI2000SS's Avatar
You want more power n/a or on nitrous?
Old May 17, 2015 | 08:24 AM
Zmg00camaross's Avatar
Get a different intake. Fast 102 etc. bet that engine as trouble ingesting 300 worth of spray. Ls6 intake and stock heads can only flow so much.
Old May 17, 2015 | 08:44 AM
mullahi's Avatar
i was thinking to increase spraying by changing the plate system to 8 fogger system so i can have safer and reliable engine
