LS1 with LS6 heads, pushrod length?
Old May 17, 2015 | 08:12 AM
Illegal Vette's Avatar
Default LS1 with LS6 heads, pushrod length?
I found a pair of LS6 heads from an '05 CTS-V at a price I couldn't refuse and after having them ported they're going on my '02 LS1 that appears to have the original cam in it. I know that the valves are a dash longer on these heads, so I'm guessing the pushrods will need to be changed. Does anyone have experience with this?
Old May 17, 2015 | 09:15 AM
According to this post the correct length is 7.375: https://ls1tech.com/forums/generatio...ls1-ls6-2.html
Old May 17, 2015 | 11:18 AM
gtotoocool1's Avatar
check your preload to be safe.i'm assume your not milling your heads?
Old May 17, 2015 | 06:45 PM
No, AI is going to do their 226 porting which is: PCD milled to ensure flatness, surface finish, & achieve desired chamber volume (57 - 69 cc).
Old May 18, 2015 | 06:53 PM
bayer-z28's Avatar
was 7.400 on mine non-milled ported 243's from an 04 with my stock rockers on a 2000 Z28. A pushrod length checker works good but a pain to use with our style heads.
Old May 18, 2015 | 07:27 PM
I guess it depends on whether the 243's have the longer hollow valves. Those are 6mm longer which is .0236, almost a quarter of an inch. That being the case the pushrods would have to go from 7.400 to 7.375. At least that's my understanding of the math, and of the endless pushrod length posts.
