RIP: LS6->LS3 swap
Its a little deeper than it looks but I still think it could be cleaned up. I'm expecting to find a piece of the piston in the pan when I finally pull it off as thats what I and my buddy who builds motors cased the markings in the wall.
Anyway I really didnt have time to rebuild the motor and being I have no machine connections or parts pricing connections it would have been quite expensive. So the motor was laid to rest as the odo ticked just over 35k miles and I began to search for a new motor.
I ended up finding an l99 crate motor (same as ls3 with valve reliefs) on craigslist still new on the stand. Motor was bought by crane cams to do some testing and was filled with oil and fitted with heads but never fired. I have to say I had my doubts about it never being fired but after seeing it I dont think I have any reservations. Here it is getting loaded into my buddies truck.
Brought it home and began piecing together the parts. I needed to obviously delete DOD and VVT to go into my camaro. So I got the parts from here as well as ebay and some sponsors. I just went with converting it into an ls3 crate motor for now. So I sold the l99 bits off of it, valley cover, timing gear, cam, oil pump etc. Then I sourced a new ls3 cam, oil pump, valley and cometic .040 gaskets to bring it up to 10.7 :1 ls3 compression and also bring quench down to the .033 range.. I thought about putting a cam in it but this is expensive as is and later on I really do want to go with a blower. I loved my cammed ls6 but a blower drives just like stock with gobs more power and the ls3 setup will handle 600whp no problem.
Heres the vvt/dod setup before delete
Today the parts started trickling in and so I got to work doing the swap.
DOD/VVT delete completed: LS3 oil pump on and cam going in.
I had some bad luck though. When putting in the cam I noticed a small bt of aluminum in the cam beaing oil hole. So without really thinking I pulled it out and went on my way. Later on I got to think that maybe the block wasnt cleaned to well before gm assembly. So I got **** and pulled the cam back out and made my only new cam TTY bolt uselss. Ended up finding a few more small pieces of aluminum in the oil goles so I cleaned them all out with brake cleaner and compressed air and started again. Only to crack the cam retainer plate torquing it down for the 2nd time..
Anyway here it is finally buttoned up. With the ls3 damper swapped for an ls2 one.
And finally as it sits now in the garage with the valley and timing cover in place. Just waiting on the heads to get here tomorrow to button it all up.
Heres whats left of the ls6 motor I've pieced out pretty much everything on it now its just down to the shortblock.
It'll be getting pulled in the next couple days to get the swap done.
Also, a cammed LS3 will walk a cammed LS1 and you can do it with less overlap, so it would drive better. Something to think about.
However since I'm using the lingenfelter box I can keep the 4x cam gear as thats what the box looks for with the 58x crank signal. It comes out and goes to the pcm as a 24x, 1x cam signal.
Ya I thought about camming it but I decided not to right now mainly because of the lack of extra funds lol not to mention I only have about another3 days to get this whole thing together and driving. So waiting for a cam was not really an option. Ideally what I would like to do in the future is possibly a sleeper cam and a blower or just a blower and leave the stock cam. Always wanted to go FI and the ls3 is FAR more boost capable in strength and power than an ls1 will ever be. Unless you start building the ls1 with better internals.
As a side note fedex didnt get here till yesterday at 4 instead of 11 like they normally do with my heads. So heres what they looked like when I got them and then after a lot of stripping. They just had some dyno testing tie on them and came with new psi 1511 springs. I had a new set of ls3 springs here that I swapped them out for. I figure I can either sell the 1511's or keep them for that possible later on cam if I choose. As opposed to wasting them on a stock cam.
http://cimg2.ibsrv.net/gimg/ls1tech....06893a60a8.jpg
http://cimg6.ibsrv.net/gimg/ls1tech....a42756b945.jpg
Side note, notice the heads here have a shiny intake valve, this is how you identify true ls3 heads with hollow intake valves. L92 heads have an intake valve that looks cast just like the exhaust valve. Between the 2 heads the lighter intake valve is the only difference
Here they are after a good paint stripping and new ls3 springs.
Found a piece of the block in the oil of the ls6 today about the size of a nickel.... I just dont know where in the block it came from
I'm hoping my shortblock holds together while I finish the rest of the car. I have the 12-bolt, Wilwood brakes all around, k-member, some paint correction, and the stereo to spend money on next...
The ls3 is built on the stand and tomorrow I'm putting it on the k member and sliding her back in.
What are you thinking for a system Jake? I did mine a couple years back. I used the infinity kappas I already had up front then two more in the sails and 4.5" ones out back. All run to a jl 600w rms 6ch amp. Then a kenwood mono channel powers a 10TW3 jl thin sub in a stealth box. It sounds pretyy good imo. and the system as a whole is pretty light. Sub and box weigh 19lbs and the jl amp is about the size of the monsoon amp
CDT Audio ES-60 Component Speakers
CDT Audio ES-60CV 2-way Component/Coax System
CDT Audio HD-1000CF 10" Subwoofer w/Stealth Box
Audiopipe APMI-55100 5-Channel Amplifier 4x98+338W @ 2-Ohm
That's a fairly good system for the car for the money. I was looking at Hybrid Audio and ARC Subs (basically ID clones). But the price difference is quite a lot for essentially the same thing.
Big thing will be installing Hushmat everywhere. It gets hot as **** in the car from the exhaust and it's loud. So all of that needs to be brought under control.
Curious did you use studs or bolts with your heads? I read some threads about people having issues with the cometics sealing with arp bolts in 04-08 but nothing in the more recent years. Freaks me out a bit because i just installed that exact combo. However my heads are dead flat and as can be seen in the pics the deck and heads are super clean.
When I installed them I cleaned both surfaces multiple times, then sprayed the cometics with copper for a little added security. The torqued the bolts as per arp instructions to 75ft lb. Waited about an hr as instructed by cometic then backed off each bolt a small bit and retightened them to 75 again to make sure they were accurate after things settled....Sounds like it should be good to me but I was just looking for some confidence here haha
I did encounter some issues and unfortunately haven driven it due to those issues. The heads I got for the motor that were new with dyno time had a header olt stripped out which cost me some time and cash to get fixed. The other issue is that the steering shaft with the bmr k member appears to be too short for the linkage coming from the firewall. If anyone has an answer to that please let me know lol. Finally my 5 month olf turn one steering pump is knocking. Heard a weird noise when I started the car that was most likely masked when the old motor knocked and noticed it was coming from the steering pump. Took the belt off and it went away. So now I have to see whats going to happen there.
Heres is a pic of everything buttoned up....Looks like an ls1 with bolt ons lol. I still need to get a better tb cable bracket and reroute the vc to tb hose.
