LS9 cam in NA LQ9
Old May 24, 2015 | 12:57 AM
ThunderboltZ28's Avatar
Default LS9 cam in NA LQ9
I recently picked up an LQ9 to swap into my C3. The previous owner of the engine also had an LS9 cam, LS2 cover, sprocket, chain dampener, and harness extension that wasn't being used so he gave it to me.
I understand there are better cams out there, but I wasn't planning on doing anything to the engine besides headers, LS6 intake, and tune.
From my understanding the LS9 cam is tailored more for boosted applications. I've only read about this cam going into turbo'd LQ4s and some NA LS3s. How well would the LS9 cam compare to the stock cam in an NA LQ9?
The motor is going in with a T56 and it has 3.55s in the rear. Mainly used for street driving, autocross, and occasional track day.
Old May 24, 2015 | 01:30 AM
Darth_V8r's Avatar
Moderator
This seems to keep coming up from time to time. The LQ9 cam, because it is deigned for boost, has very little overlap. As a result, without the forced induction, it will not carry power on the high end, which in a corvette, is where you want the power.
If you do the work, you'll find you just invested a bunch of time into a cam for no benefit. If it were me, I'd keep the stock cam over that LS9 cam.
Actually, if it were me, I'd spring for a cam motion drop in cam, so I wouldn't need to worry about springs, clearance or anything, and I'd have a great runner for that C3.
Old May 24, 2015 | 01:19 PM
I figured as much. I was kinda hoping a cam would be better than no cam.
I guess I'll stick with the stock cam for now until I can put together the budget for a proper heads and cam setup later.
Old May 24, 2015 | 01:32 PM
Tuskyz28's Avatar
The LS9 cam is really meant for a rectangle port head.... If I was go run that cam I would pair it up with LS3 heads/intake. That cam has a wide split. Ls3 heads seems to perform well with wide split cams.
