another head gasket question
Old May 24, 2015 | 04:24 PM
BeaversTA's Avatar
Default another head gasket question
Would there be any problems running a cometic head gasket with a bore of 4.060 instead of the 4.030?
ls2 with tfs 215 small bore heads
Thanks
Old May 24, 2015 | 05:13 PM
Burken01's Avatar
It isn't ideal, but it will work.
Many people run 4.100" ls9 head gaskets even on a 5.3 engine with no problems.
Old May 24, 2015 | 08:13 PM
Darth_V8r's Avatar
Moderator
I've heard people say that having a larger ridge due to the gasket gap can increase potential for detonation. if you're staying stock compression, should be fine. if you're going to go crazy, consider shopping around some more.
Old May 24, 2015 | 09:11 PM
BeaversTA's Avatar
Going to run a .040 gasket with 63cc heads, so compression will be around 11.6. The 4.060 gasket is around $30 cheaper and are in stock locally.
Old May 24, 2015 | 09:19 PM
Darth_V8r's Avatar
Moderator
probably be ok
