Heads up for those running ported heads..
Old Jun 4, 2004 | 12:14 AM
Z28Venom's Avatar
Default Heads up for those running ported heads..
Well.. after much reading on the site and picking my brains to figure out why my car was smoking and burning oil. I've definitely found out what the problem is.
But in the course of finding the problem. I've done the following:
Ghetto PCV mod (fuel filters in the PCV line)
New Seals ( only $16 + shipping)
More Performance valve spring tool ($120 for nothing)
Only to find out that the problem was the big *** hole left at the bottom of the intake rocker bolt after porting and polishing.
I've done 3 pushrod swaps since my h/c swap, and two of the times I didn't use anything to seal the bolts when they were put back in. Well, during the course of a month without much driving my car had used 2qts.. It was also blowing blue smoke.
So for those burning oil after a h/c swap.. Learn from my mistake and buy some good sealant and seal your rocker arm bolts.
I'll post pics tomorrow of holes and my intake runners.
Sorry this is so long..
But can someone recommend a good sealer.
Old Jun 4, 2004 | 07:51 AM
haole_boySS's Avatar
Teflon pipe dope in a tube. Works wonders.
Old Jun 4, 2004 | 07:52 AM
Country Boy's Avatar
Senior Member
Yep! Same stuff I used with zero problems.
Old Jun 4, 2004 | 08:52 AM
02WSsicks's Avatar
I used loc tight red on the rocker bolts no problems so far.
Old Jun 4, 2004 | 09:40 AM
99C5JA's Avatar
I just put some RTV on mine (along with Loctite Blue). No problems.
Old Jun 4, 2004 | 09:52 AM
foff667's Avatar
LS1TECH Sponsor
yah i too used a good amount of loctite red on my bolts(thx crainholio) & no problems so far*knock on wood*
lata
Bill
Old Jun 4, 2004 | 09:58 AM
Steve Burger's Avatar
LS1TECH Sponsor
Blue Loc Tite and no burning oil.
Old Jun 4, 2004 | 10:03 AM
silverbullet00's Avatar
I was going to post about this as well. I burned about 2qts of oil in about 600 miles of driving after ported heads. I will try the sealer thing and hopefully it works.
Old Jun 4, 2004 | 10:28 AM
soslo's Avatar
I used this stuff on the lower 3/4 of the bolt, and loctite red on the upper 1/4...no problems so far, though its only been 4 days
Old Jun 4, 2004 | 11:11 AM
Z28Venom's Avatar
It was totally weird the way the car would smoke so I knew something was up..
It would barely puff anything on startup, so I would think that everything was ok. There was no set amount of time before it was just totally start smoking. Now, I know that there was a delay in smoking because it took the oil a while to work itself past the bolts. Then all hell would break loose..
Old Jun 4, 2004 | 11:18 AM
2001CamaroGuy's Avatar
I filled the bottom of the hole in my heads with some aluminum oxide putty (kind of like JB weld but better) to not only seal it, but to also get rid of the hole so air would have a smooth surface to go over.
