Daily drive cam selection
Old May 28, 2015 | 10:09 PM
01WS6BLACKLS1's Avatar
Default Daily drive cam selection
Hey everyone just a cam question. My ls1 has 241 heads, I would like to keep stock stall its a a4 with 3.23 gears. Looking to gain 25-35 horses with a proper tune of course, would the '02' and up ls6 cam be a good choice, or the hot cam? I don't plan on touching the heads just want a little bump in power and not break the bank. ps I drive like 7 miles round trip to work and the occasional weekend cruise thanks
Old May 28, 2015 | 10:12 PM
also my mods are lid, 1 3/4 hooker headers, no cats, magna flow catback and frost mail order tune
Old May 29, 2015 | 12:41 AM
JakeFusion's Avatar
Super Hulk Smash
Hot Cam would be better than LS6. There are some aftermarket grinds that might work better, but the Hot Cam 218/228 112 is very close to what you want with a stock stall and a modest bump in power.
Old May 29, 2015 | 11:14 AM
Default cam
Just curious being the hot cam has smaller lift, compared to the ls6 cam, why would it be a better choice just curious? I know enough about cams to get me by.
beautiful car by the way love the rims too!
Old May 29, 2015 | 11:45 AM
Tuskyz28's Avatar
Lloyd Elliot have two grinds that works really for this type of scenario...
First one is a 215/219 duration 604/607 lift on a 113 LSA- his description of this cam is called a "sleeper/torque monster". Gains of torque all the way from idle to 6000 rpm with a smooth idle.
Second cam that looks interesting is 223/227 duration 610/614 lift on a 112 LSA. Can be used with stock gears and factory stall. Mild idle with great all around power. 1500 to 6200 rpm.
If you on a tight budget I would recommend installing a trailblazer stall.
Old May 29, 2015 | 12:23 PM
thunderstruck507's Avatar
Lift is less important than duration/ valve events.
Old May 29, 2015 | 12:29 PM
Rise of the Phoenix's Avatar
This would be a great option for you. Courtesy of Mr. Ed Curtis:
LSx "StreetBeast-TQL" Hydraulic Roller Camshaft
Specs: 223*-227*-112*-.625"-.619"
Old May 29, 2015 | 07:42 PM
Thank fellas I appreciate the input and help
Old May 31, 2015 | 08:11 PM
gtotoocool1's Avatar
hell,the stock TC is too small for the stock cam.
if you can swing it,get a TC to go with the cam.3000 stall works good with a baby type cam.
Old May 31, 2015 | 08:26 PM
Tuskyz28's Avatar
Know you don't want to spend that much money.... The trailblazer stall I mentioned earlier in this thread stalls around 2500 rpm from the factory. That would be my choice for a budget converter.... I'm sure you can send the stall off to a sponsor here and get them to bend the fins in the converter and change the stator in the stall more more which would probably still be cheaper than buying a 900 dollar torque converter....
Old May 31, 2015 | 09:55 PM
Default cam selection
Well I guess this raises my other question about the ls6 cam. Would that be a good cam too I guess, especially on a tight budget. Also if I did lets say go with a trailblazer stall would that effect the tune with or with out a cam?
Old May 31, 2015 | 10:28 PM
A.R. Shale Targa's Avatar
http://www.texas-speed.com/p-161-com...-camshaft.aspx
call theses guys here for a cute little custom cam; plus all the necessities can be gotten from them....one stop shopping
Old Jun 2, 2015 | 08:44 PM
BBATCAR's Avatar
I'm sure any of the sponsors can steer you the right way. My baby cam in signature works well with the stock stall. I do plan on going to the FTI 2600 stall that goes for $330 but I have no problems with my stock stall and the cam I have in my sig. I have a higher lift because I have the heads to support it. Martin@Tick spec'd mine and I'm very happy with it.
Old Jun 4, 2015 | 08:11 PM
thanks so i know the next question i have doesnt belong on this but does the fti stall work well then i take it i was looking at them a while back
Old Jun 4, 2015 | 09:01 PM
BBATCAR's Avatar
If you look at FTI stalls they say that they work well with "220/220" type baby cam. That is why I started with a stock stall but knew I could go to a small stall with the cam I was spec'd. It all depends on the cam. A small cam works well with these stalls but will be ok with a stock stall.
Old Jun 4, 2015 | 10:10 PM
cool its good to know they are a good converter. i looked at those back in the winter time when i had the car put away. also I have read to that a stall is a good mod to do even before a cam, I thought about stalling the car first because people said it changed the way the car launches and makes it a lot of fun. I might just throw in a 2800 stall from them guys first that is what they said i could use even with a stock motor.
Old Jun 5, 2015 | 04:12 PM
you will love your TQ.I had the TR220 in my old Z/28,ran it with the stock stall for about a week.after the 3000 stall went in,it was a whole different animal.
Old Jun 5, 2015 | 09:06 PM
I noticed this on jegs website http://www.jegs.com/i/JEGS-Performan...rentProductId=
what do you guys think?
Old Jun 9, 2015 | 02:11 PM
Default hawks third gen cam
hey after further researching hawks third gen has a CAM, 220/220 .581"/.581" CAMSHAFT I e-mailed them and the stock converter will be fine. Has anyone ran this cam. what I have read online its a decent cam. thanks again guys?
