06 5.3 or 01 6.0 for my car
Old May 29, 2015 | 02:45 PM
dewchugr's Avatar
Default 06 5.3 or 01 6.0 for my car
I need a little advice. I have a 5.3 out of a 2006 truck of some sort with 60k on it. It's not complete, i need front cover, some accessories, brackets, harness and ecu. I have part of a harness that came with it but it's hacked up. It needs a cam and lifters which I'd want to do regardless.
I may have a change to get a totally complete 6.0 with 170k out of an 01 truck of some sort really cheap. It's in a yukon denali. would it be the LQ9?
This would be going in a 71 a-body convertible with as yet undetermined trans, t56 or 4L80 and probably 3.73 gears. I want a nice reliable, quick street car.
I know the 06 5.3 is better than the earlier ones and this one is pretty low miles, but, is there any reason I should use the 5.3 instead of the 6.0? I have to pay body and paint work on the car so budget is important. If the 6 looks good I'll buy it anyway tho.
Thanks
Old May 29, 2015 | 07:45 PM
CattleAc's Avatar
If this has such low miles...why is it that far apart...???
It's good you already own it...but it sounds a little sketchy.
This would be going in a 71 a-body convertible. I want a nice reliable, quick street car.
Bang for the buck , the complete 6.0L is your huckleberry...it's all there, (the little stuff ads up to complete your 5.3) plus the extra cubes are an added bonus...
Old May 29, 2015 | 11:18 PM
dewchugr's Avatar
The 5.3 was a warranty replacement at a dealer because of a lifter roller that went south and damaged the cam. They apparently robbed parts to put on the replacement. It doesn't matter at this point as the jerk sold the 6 out from under me. I'm not in a hurry so I may find another.
Old May 30, 2015 | 10:55 AM
99Brd's Avatar
6.0 in my opinion. More cubic inches. Bigger bore. More horsepower... JMO.
Old May 30, 2015 | 10:56 AM
99Brd's Avatar
Forgot to say if it's out of a Denali it's probably an LQ4...
Old May 30, 2015 | 02:20 PM
Tuskyz28's Avatar
Do you have a horsepower goal ?
Old May 30, 2015 | 03:06 PM
redbird555's Avatar
I'd go for the 6.0 it will be an lq4. More cubes=more power
Old May 30, 2015 | 10:20 PM
dewchugr's Avatar
Not really, just not to be embarrassed by a mustang.
Old May 31, 2015 | 07:23 PM
tmoney82's Avatar
I'll do the 6.0! You are building the motor to a performance motor right? If that the case, half of it would have new parts!
Old May 31, 2015 | 10:39 PM
CattleAc's Avatar
I've had that happen...If you have time, hold out for the 6.0.
Or...do what I did with my A-body...I decided to install a 5.3 to get all the details of the swap ironed out...with the bonus of being able to drive it sooner than later.
I have my 6.0 on the engine stand now, and am building a forged bottom end as my budget allows...
Old Jun 1, 2015 | 06:14 AM
Tuskyz28's Avatar
I'll go 6.0 with some goodies.... cam, headers , tune, etc.
It don't take much to crack the 420 horse mark at the crank with a 6.0.
http://www.hotrod.com/how-
to/engine/hrdp-0710-6l-ls-series-small-block/
READING THAT ARTICLE IS VERY HELPFUL.
Old Jun 1, 2015 | 10:50 AM
badformulaLS1's Avatar
The only way I'd use a 5.3 is if it was going to be installed with a turbo at the same time. If you are staying all motor or doing nitrous, then definitely 6.0. If you want to boost it but will be N/A for a while and doing the FI later down the line, still go 6.0 so you have more N/A power to play with for the time being, and when you do go FI it'll take less boost to make the same power vs a 5.3. 6.0 FTW.
Old Jun 1, 2015 | 11:05 AM
KCS's Avatar
KCS
Moderator
I vote the 6.0L. Even if it's an LQ4, it will still have a better power output than the 5.3L with the right modifications.
Old Jun 1, 2015 | 04:22 PM
dewchugr's Avatar
Thanks for all of the comments, I have some things to think about.
