Can I Re use these gaskets?
Old Jun 3, 2015 | 08:25 PM
onesloGTO's Avatar
Default Can I Re use these gaskets?
I'm about to start swapping my good 5.3 parts to my 4.8 after melting a piston and breaking the rings on the 5.3. I'm going to swap the cam and lifters into the stock 4.8 as well as the oil pan since mine is already setup for a turbo return.
Can I Re use the felpro oil pan gasket?
Timing cover gasket?
I have ls9 I believe head gaskets. They are multi layer (5 or 6 layers) can those be used again?
Old Jun 3, 2015 | 11:12 PM
blk00ss's Avatar
I've reused oil pan gasket and timing cover gasket numerous times. As well as valley cover and rear cover gaskets. Even water pump gaskets. But the ls9 gaskets are a one time deal I believe. At least I've never reused them.
Old Jun 3, 2015 | 11:27 PM
Jontall's Avatar
The GM service manual says that the oil pan gasket should be replaced; timing cover too.
Old Jun 3, 2015 | 11:55 PM
itsslow98's Avatar
Oil pan and timing cover gaskets are $30/ea, cheap peace of mind from having to do it over if it ends up leaking. Head gaskets are one time use.
Old Jun 4, 2015 | 07:46 AM
Exidous's Avatar
The only gaskets I'd reuse are the intake gaskets, if they're in good shape. If you had torqued down the oil pan and let it sit for a month or two and needed to remove the pan I'd say okay but not after it's been through hundreds of heat cycles. Don't forget the RTV for the seams on the front and rear cover!
Old Jun 4, 2015 | 08:09 AM
onesloGTO's Avatar
Thanks guys
Old Jun 5, 2015 | 01:08 PM
onesloGTO's Avatar
Ok, I got a new oil pan gasket, timing cover gasket, water pump gasket, and had gaskets. Should I replace valley cover gasket as well?
Am I missing anything else?
Old Jun 5, 2015 | 01:37 PM
thunderstruck507's Avatar
I reuse timing cover gaskets and oil pan gaskets, just with a thin smear of RTV and never had a leak.
Head gaskets and non ARP head bolts are trash once used
Old Jun 5, 2015 | 02:04 PM
blk00ss's Avatar
Definitely don't have to on the valley cover. It doesn't see a lot of oil.
Old Jun 5, 2015 | 02:50 PM
MuhThugga's Avatar
And the valley cover is easy to replace if it develops a leak.
The way I look at it is if you have the engine sitting on a stand, then it is much easier to install all of that stuff new on the stand than it is to have to replace reused parts in the car.
Old Jun 5, 2015 | 06:23 PM
onesloGTO's Avatar
Should I be able to reuse my exhaust manifold gaskets? They are metal.
Old Jun 5, 2015 | 09:53 PM
blk00ss's Avatar
Yup. I've reused the same ones that were on my car when I bought it in 06'. That includes at least 6 different engine swaps lol. Just recently replaced them and only because the headers I bought came with a new set.
