ls1 through a rod, need HELP!
Well if this is the case my block might be damaged, so I might be looking into a good complete bottom end. Any good deals around on complete built bottom end stokers? Cheaper the better, still in school and have very limited $$$
Thanks for all your help, Chris
Sounds to me like you just spun a bearing. If you "threw" a rod, that generally means it exited the engine via the oil pan or side of the block. If the crank journal isn't torn up too badly just have the journals machined down and go with oversized bearings. That is, if the the rod isn't dis-colored from too much heat.
You probably started the spun bearing the last time you hit the bottle and it just got worse from normal driving.
I wouldn't suggest driving it anymore until the problem is fixed. Good luck....
Mike
Eagle 4.125" rods = ~$650 (with really good ARP bolts)
3.905" bore/1.125" Compression height pistons = $700
That’s the major parts, and then there is the $500-$600 for machine work and probably another $750-$1000 for bearings, bolts, gaskets, etc....all the little things that will get forgotten until the last min.
Thanks for all your feedback!,
Chris
http://www.horsepowerengineering.com/GM/ls1engines.html
Another suggestion, check out "www.keithcraftmotorsports.com" for some really good prices on short and long blocks or complete engine packages. I am getting an Eagle 4" stroker kit from them for around $2100 balanced. I know the Eagle stuff is questionable right now but at that price I can build another motor for what Lunati wants for their kit.
Chris
Unfortunately he is shooting dry. If something is to blame, you know what the answer will be.
BTW 125 dry is like 100 wet. Not what I would call a Huge shot.
https://ls1tech.com/forums/showthread.php?t=177441
Regards,
Chuck
