5.3 to 4.8 rotating assembly?
Old Jun 14, 2015 | 09:29 PM
onesloGTO's Avatar
Default 5.3 to 4.8 rotating assembly?
After melting a piston on the 5.3 everything is out and torn down. The 4.8 I was going to use looks a little rough. Needs cam bearings ect...
Could I swap the 4.8 crank to the 5.3? I'll be using the 4.8 pistons with new rings and rod bearings. So basically swapping the rotating assembly from the 4.8 to the 5.3 block will make the 5.3 a 4.8?
From what I've read they are identical aside from the crank.
The 5.3 cylinder walls still look good in my opinion. I may hone them a bit, but the walls in the 4.8 look worse.
Old Jun 14, 2015 | 09:47 PM
96capricemgr's Avatar
5.3l crank and rods with 4.8l pistons
Old Jun 14, 2015 | 10:37 PM
onesloGTO's Avatar
How do I take stock pistons off 4.8 rods and put them on the 5.3 rods?
Old Jun 14, 2015 | 11:18 PM
A.R. Shale Targa's Avatar
you must also use the 4.8 rods as they are longer to make up for the difference in rod throw offset (3.622"-3.268"/2)=0.177" which means the 4.8 rods should measure 6.275" in length
Old Jun 15, 2015 | 12:21 AM
alowerlevel's Avatar
Either take them to machine shop to have done or do it yourself....
Old Jun 15, 2015 | 02:02 AM
teangjivi's Avatar
Old Jun 15, 2015 | 08:04 AM
onesloGTO's Avatar
Ok I think that's the route I will go. I'll just put the 4.8 flat top pistons on the 5.3 rods and keep running the 5.3
Thanks for all the help guys, I appreciate it!
