help with cam for ls1!
Old Jun 22, 2015 | 08:34 AM
LS1TL's Avatar
Default help with cam for ls1!
Trying to decide on a cam for my daily driver, new a4 going in with fti 3200 street brawler. Car has pacesetter LTs, ls6 intake, and stock heads. Any advice would be greatly appreciated!
Old Jun 22, 2015 | 08:39 AM
farmington's Avatar
I have a baby cam (224r) but it is a very nice street cam. good bottom end, nice power up top and a nice sounding idle
Old Jun 22, 2015 | 08:44 AM
LS1TL's Avatar
I was looking into the ts 228r. I guess another question I have would be what other changes would I need to make to my motor for it to run correctly? I've never done a cam installation yet so I'm a bit nervous
Old Jun 22, 2015 | 08:47 AM
thunderstruck507's Avatar
I think you would be pleased with something like this:
http://store.cammotion.com/the-titan3-1
Old Jun 22, 2015 | 08:52 AM
HCI2000SS's Avatar
What gear do you have?
Old Jun 22, 2015 | 08:58 AM
LS1TL's Avatar
Right now 273s. But thinking about going bigger if needed
Old Jun 22, 2015 | 09:31 AM
HCI2000SS's Avatar
I'd strongly consider a gear with a cam swap
Old Jun 22, 2015 | 09:37 AM
LS1TL's Avatar
Would 3:42s be large enough? Or bigger?
Old Jun 22, 2015 | 09:59 AM
3.42 would be fine
Old Jun 22, 2015 | 10:54 AM
HCI2000SS's Avatar
A 3.42 would be a pretty big increase and would greatly help. If it's a daily driver it would be a good choice IMO
Old Jun 22, 2015 | 10:56 AM
LS1TL's Avatar
Well I was thinking 3:42s could probably be found for pretty cheap. Or 3:73s but I'd like to keep some of my gas mileage
Old Jun 22, 2015 | 11:04 AM
depending on how fast you drive you might not see any difference in MPG at all
my car with 3.42s and the cam/engine setup turns out best MPG at 75-80 mph, if I drive 65-70 is has a harder time keeping the converter locked and also falls out of the butter zone of efficiency
so for example if I wanted to drive 70mph all the time it might be better if I had 3.73s
Old Jun 22, 2015 | 11:30 AM
LS1TL's Avatar
So for lower speeds such as 65-70 then 3:73s would be the better choice
