Rod length question 408 build
Old Jun 25, 2015 | 12:16 AM
SilverSS's Avatar
Default Rod length question 408 build
This is on a 6.0 iron block. Planning my build and have on hand the 4" crank and Wiseco pistons at 1.115 CR Height. Now, my current deck height is at 9.221". With a 6.125 rod, it puts me at .019 above the deck and quench with an LS9 head gasket puts me roughly at .032 quench which i don't feel too comfortable with. I have on hand 6.100" rods which put me at .006" in the hole and I am fine with that. My question is, will the 6.100" rod pull the piston down too low out of the already short bore of the iron block and cause issues?
Compression will be roughly 10:1ish and I am stuck on the LS9 gasket due to it working so well. This motor will be lightly boosted too.
Old Jun 25, 2015 | 01:30 AM
VLS1's Avatar
No way should you be considering running a positive deck that measures anywhere near that!
Old Jun 25, 2015 | 01:35 AM
Burken01's Avatar
I ran that much on my turbo build.. It happens when you get the block decked..
As long as you measure and have quench above .035 it will work fine
Old Jun 25, 2015 | 07:10 AM
KCS's Avatar
KCS
Moderator
It should be okay. I'm 99% positive that Wiseco shelf pistons will work with either 6.100" or 6.125" rods.
Old Jun 25, 2015 | 08:08 AM
SilverSS's Avatar
Thanks, so you see no issue pulling the piston down .025" further down in an iron block with the 6.100 rod? I'm probably over thinking it a bit but I just wanna be sure.
Old Jun 25, 2015 | 09:11 AM
KCS's Avatar
KCS
Moderator
No, there won't be an issue if the skirt was designed for it. If you want to be sure, I would consult with someone at Wiseco. They'll know better than anybody.
