Valve springs, single or double?
Old Jul 9, 2015 | 10:29 AM
gothic_sera's Avatar
Default Valve springs, single or double?
I see the Comp 26918 being referenced everywhere for these engines and mostly good reports following the redesign.
With a view to keeping the valve train weight to a minimum it makes sense to fit the single beehive style springs... Trouble is, am I pushing the limit with my cam with .621/.612 lift - getting very close to the .625 maximum.
Installed height is stock 1.800", coil bind is quoted at 1.100".
So should I run 26918 or look for something else?
Old Jul 9, 2015 | 10:41 AM
Tuskyz28's Avatar
BTR valvespring is what I recommend.
Old Jul 9, 2015 | 10:47 AM
kinglt-1's Avatar
No you do not want a 918 for that application. PSI makes a beefier Beehive if that is the route you wish to go. Comp also makes a Conical spring that looks interesting but I have not heard much about it lately. That being said, A good dual spring kit is what most will recommend...BTR, PAC, Lunati all make a decent set of dual .660 lift springs. Actually they all probably come from the same source.
Old Jul 9, 2015 | 02:24 PM
Brian Tooley Racing's Avatar
I think you could go beehive or dual, whichever you're most comfortable with, we have both in stock.
Here's the PSI beehive: http://www.briantooleyracing.com/625...e-springs.html
Here's our dual springs with titanium retainers: http://www.briantooleyracing.com/660...ers-sk001.html
Old Jul 9, 2015 | 03:53 PM
Thanks for the feedback. BTR looks the way to go... The beehive's are more or less exactly the same spec as the 918's on paper at least.
I'd prefer beehive just to keep the valve train weight lower - is this sensible or would the higher spring rate of dual springs be more beneficial?
Full cam specs are:
Dur @ .050 236/242
Lift w/1.7 .621/.612
Lobe sep. 112
Planning on turning the motor to around 7k assuming that power isn't dropping off by then.
Old Jul 9, 2015 | 03:55 PM
Full cam specs are:
Dur @ .050 236/242
Lobe sep. 112
Do you have the seat duration and duration at .200" for the cam lobes? That way we can gauge lobe intensity.
What's your valve weight? Running stock rockers I assume?
Old Jul 9, 2015 | 04:07 PM
Sorry, I don't have anything else other than the specs above, it'll be a Cam Motion custom grind.
Stock rockers with trunion upgrade. Valves are stock 2.0 and 1.55. Believe they are around 100 and 86 grams respectively.
Old Jul 9, 2015 | 04:12 PM
drew408's Avatar
I've always gone dual....if a single breaks and drops a valve,you'll wish you'd have gone dual.
Now it's rare for any valve spring to break if it can handle the lift but **** happens!!
Old Jul 9, 2015 | 04:21 PM
squalor's Avatar
If you let Cam Motion use the seat durations they like to grind with, your 236/242 @ .050 will be 291/297 @.006 , a difference of 55 so the PSI springs will work. Asking for a lower lift like .612/.603 would work better.
Mr. Tooley, those beehive retainers on your site have a SUPER price. I want a set of those for my PSI springs, like tomorrow.
Old Jul 9, 2015 | 04:26 PM
Cam Motion cams are generally easy ramp speeds, and yes your stock 2.00" intake valve should be 100 grams, so you should be good to go!
Old Jul 9, 2015 | 04:27 PM
UPS hasn't run yet... there's still time...
Old Jul 10, 2015 | 01:39 AM
Thanks for your help everyone.
I'll get some springs ordered in the next few days. Just to be clear these springs are the ones I need? Do they work with the stock retainers?
Old Jul 10, 2015 | 01:43 AM
geazowksitn's Avatar
Old Jul 10, 2015 | 09:50 AM
kinglt-1's Avatar
I would do the PSI 1515 Beehive if going that route.
Old Jul 10, 2015 | 10:04 AM
Yes, those would be the ones you need.
The ML1515 are designed for a 1.950" installed height like the LS7 heads and some Hemi heads. They will not work on standard 15 degree LS heads.
PRODUCT DESCRIPTION
PSI 1515ML .650" Lift Beehive Springs. Designed for LS7 and other 1.950" installed height applications.
140 lbs @ 1.950", 405 lbs @ 1.300", Coil Bind 1.225", 1.290" OD, .630" ID
Old Jul 10, 2015 | 10:16 AM
redtan's Avatar
Brian do you sell a complete PSi 1511 kit like you do the BTR duals?
Trying to piece together parts around those springs to go on a bare head.
Old Jul 10, 2015 | 10:53 AM
redbird555's Avatar
I loved my psi 1511's ion my old setup even with 25000 miles on them in the end they pulled to 6800 rpm cleanly and never had a hiccup. You still run the risk with duals.... That inner spring may save you if you're just idling but it wont do anything if it lets go at 6000 rpm.
With that said either is a good choice but I wouldnt get 918 a number of years back they had a lot of failures. They are corrected now but I still have seen a couple break and idk just something about that whole incident where people lost motors leaves a bad taste in my mouth.
Old Jul 10, 2015 | 12:24 PM
squalor's Avatar
and that makes me wonder about their new conicals ?
The PSI 1511 have never had a documented failure. Are they made out of Kobe steel ?
Old Jul 13, 2015 | 03:35 AM
Perfect, thanks for the help everyone.
I'll order some 1511's in a couple of weeks
Old Jul 13, 2015 | 11:25 AM
kinglt-1's Avatar
Fwiw I witnessed a comp dual break at higher rpm on a 383 LT1 and the engine survived. The engine later came apart due to a poorly cast crank which resulted in a failure. Tops of the pistons were fine, nothing made contact.
