408, how high can I spin it?
Old Jul 9, 2015 | 10:36 PM
VandykeT/A's Avatar
Default 408, how high can I spin it?
Right now my limiter is at 7200 so I can make it through the traps. It peaked around 6500 and with the T56, 4.30s, and a 27" tire I'm trapping right around 129 and I'm assuming very close to the limiter. I'm afraid if I change tracks (129 was at 3000 feet) I'll run out of gear. Basically is it safe to turn a Arp 2000 bolted forged 408 in the 72-7300 rpm range just to go through the traps or should I look at re gearing the car pretty quick.
Old Jul 9, 2015 | 10:56 PM
NAVYBLUE210's Avatar
From: Coast of San Mateo County Between Pacifica & HMB
Would it be easier to go to 28"or 29" tall tire? 29" tire = 3.98:1
7200 rpm becomes 6700 with 29"
7200 rpm becomes 6900 with 28"
Bottom end not as much concern as top end.
Hydraulic or Solid Roller Cam?
Old Jul 10, 2015 | 06:23 AM
tmoney82's Avatar
Why so much gear to begin with? I would think that stroker has plenty of grunt down low? Just asking ?
Old Jul 10, 2015 | 09:22 AM
KCS's Avatar
KCS
Moderator
The shortblock may be okay, but you're valvetrain may have problems.
Old Jul 11, 2015 | 03:27 AM
VandykeT/A's Avatar
The car was set up for stock bottom end. It didn't peak until 6900 so I needed the gear. The 408 is on the edge. It's a hydraulic roller. PAC700 springs stock rockers and ls7 lifters. And I would go to a 28" tire but the 27"s are brand new and I have a 4.10 gear all ready.
Old Jul 11, 2015 | 09:28 AM
Swap the gears, then 28" tires after the 27s wear out.
Or sell the 27"s. 4.10s with 28" =3.95:1, 7200rpm-6600rpm.
Old Jul 11, 2015 | 10:46 AM
98hc4mula's Avatar
not to hijack, I was going to post similar question about a different set up.
408 engine, good to go top end (Mamo heads AFR 235, short travel linked lifters-hydraulic)
4l80e transmission and 410 gears.....what would 26 vs 28 inch tire do as far as RPM when racing int he quarter mile?
I am trying to decide what size slicks to buy for 15x10 rims.
been racing on the street ET drag radials and I cannot hook very well at the track.
thanks
Old Jul 11, 2015 | 11:05 AM
Simple Math, 2" differential 26"-28" 7.7% fewer rpm
28"-26" 7.14% more rpm.
Need to know trap rpm currently.
Roughly 500RPM @ 7000 RPM
Old Jul 11, 2015 | 11:34 AM
98hc4mula's Avatar
Thank you for responding. makes sense. I dont know the trap RPM spot on. I do know that it was way up there last time I raced. I will have to check when I am at the track next time.
again thanks
