BTR VS Tick Performance Cam
Old Jul 16, 2015 | 03:23 PM
Darth_V8r's Avatar
Moderator
Anything Martin specs you is going to be good. If he has Kip grind it, you will be very happy. Both are excellent cam specialists
Old Jul 16, 2015 | 03:30 PM
Camaro9781's Avatar
They both have great customer support, I've just been in contact with tick more. Mainly because that's where I just ordered all of the transmission parts from. But yeah martin suggested the SNS stage 3 so I guess I will go with whoever has the cam motion core. Now all I need to worry about is the head gasket thickness I should go with!
Old Jul 16, 2015 | 04:05 PM
Camaro9781's Avatar
Thank you everyone for all of your responses. Love this site
Old Jul 16, 2015 | 05:46 PM
JakeFusion's Avatar
Super Hulk Smash
You're looking at essentially what I have... I have a Cam Motion ground EPS Cam using EPS lobes (which are softer than the LSL in those cams, but don't give up anything in terms of power).
Old Jul 17, 2015 | 03:08 PM
Kingc8r's Avatar
FYI you can have a BTR cam cut by Cam Motion....
Old Jul 17, 2015 | 03:43 PM
sabersaw30's Avatar
I have a Btr4 cam and love it. Good low end torque and top end pull. Thats threw a 3600 fti stall auto with 3.73 gears. Have not had it back to the track with new cam. Hoping for low 11s.
Old Jul 17, 2015 | 09:51 PM
Camaro9781's Avatar
The deciding factor will be how much more an 8620 cam motion core will be between the 2 companies. The customer service has been great from both vendors.
So just to clarify, the BTR 4 will have a tad bit more low end than the SNS 3 because it has less overlap? I'm not sure what the overlap is on either cam I just know that if the LSA goes down then overlap will increase vs the same cam with a higher LSA and less overlap. And I do understand at the end of the day LSA is just a sum of numbers
Old Jul 17, 2015 | 09:59 PM
JakeFusion's Avatar
Super Hulk Smash
Overlap is a wash. The valve events are also a wash. The BTR cam uses softer exhaust lobes which seems to dyno higher.
The Cam Motion billet core makes the cam 449.99.
Old Jul 18, 2015 | 12:33 PM
slowsol95's Avatar
Both cams will drive the exact same, literally. You're splitting hairs trying to find a discernable difference between the two. Run the numbers into a camshaft overlap calculator, I'm pretty sure last time I did they were both around 16 degrees overlap. Lsa plays a role in overlap, but its not the only factor. You can't just look at one cam with a 111 lsa and say it will have more overlap than a 113 lsa. Generally speaking that trend is true for given durations, but there are other factors that play into it.
Old Jul 18, 2015 | 04:03 PM
subeone's Avatar
Cams are very similar. Flip a coin to choose one i guess. Cam motion or comp they're both good, don't fall for the hearsay about comp cam failures.
Old Jul 19, 2015 | 04:45 AM
Public Enemy's Avatar
I tried both:
1. 2006 Corvette A6 C6 LS2 - The heads, cam and fast intake all from Brian Tooley (Stage 4 cam, port matched intake, 220cc trick flows) and it dynoed 502whp SAE through a stalled C6. Converter was a Circle D 2E
2. 2002 Fbody Camaro Z28 A4 LS2 - PRC 227 Heads, Tick SNS Stage 3 Camshaft, unported fast 102mm. It dynoed 489whp SAE. Converter was a Circle D 4c.
Both cars had 1 7/8 headers... Both LS2.. Both converters locked.. but obviously the induction system differs from an fbody to a corvette. Judging by the number, they should perform almost the same, the BTR dynoed higher because of the ported 102mm and maybe the drivetrain. Pick anyone of these cams, both Brian and Martin are great support.
Old Jul 19, 2015 | 08:04 AM
  #32
Darth_V8r's Avatar
Moderator
Is it possible the vettes dual exhaust was worth some of the difference over the F body?
Old Jul 20, 2015 | 05:27 AM
  #33
I'm not sure.. the fbody did have a 3 inch collector with a 4 inch vibrant merge collector and then a cutout. The vette had a 3 inch dual exhaust.
Maybe the heads make a little difference.. I'll see if i can post some pics of Tooleys tfs 220 next to prc 227 side by side. The heads looked similar in valve size and ports/runners.
Old Jul 20, 2015 | 05:40 AM
  #34
I don't have any pics showing the ports from the inside as I received them fully assembled.
Old Jul 20, 2015 | 07:21 AM
  #35
SoonerBrad88's Avatar
I have a comp ground SNS Stage 3 and I was pretty pleased with the performance. It's actually a custom grind but based off of the SNS but the lift and lobes are changed to work better with my rockers. I think either cam will be a good choice. And I would just cut valve reliefs in the pistons and run the smaller head gasket to bump the compression.
Old Jul 20, 2015 | 12:54 PM
  #36
A.R. Shale Targa's Avatar
Without fly cutting the new Pistons, I'm guessing neither cam will clear with a .040" gasket. Which a clean up cut on the heads and the thinner gasket is the best way to get elevenish compression but then the BTR stage 2 on the 8620 CM core would be the best balance of all the compromises.
Old Jul 20, 2015 | 01:07 PM
  #37
ragtopz28's Avatar
I like my BTR Stage III...the Stage IV wouldn't fit with heads cut .015 so I went with the III The power was still climbing fast at 6700rpm (I asked tuner not to spin it past that on my SBE)
Old Jul 21, 2015 | 08:22 AM
  #38
Camaro9781's Avatar
Thanks guys for all of your responses! Love to hear everyone's opinion and experiences. I think I will just be running a 051 head gasket though and not worry about PTV issues.
Old Jul 31, 2015 | 01:32 PM
  #39
Sales@Tick's Avatar
FWIW, we've been using Cam Motion since February of this year.
All of our shelf cams lobe profiles have been redesigned by myself and they are all 53-55* major intensity and we don't push the .200" number. I have tried everything from fast to slow, and 9/10 with the kind of parts most LS engines are using the slower smoother lobe profiles make more power.
Comp had a snafu at the beginning of the year regarding supply and demand of cores due to a change in their system they implemented to help stocking and ordering. They pretty much ran out of cores. We were experiencing wait times of 2-3 weeks and up to 1 month on most of the cams we were selling and up to 2 months on some of them, it depended on the specs and what they had available. That is just not acceptable when you sell as many cams as we do.
So we turned to Kip and haven't looked back since. I am very happy with the product we receive from Kip and don't see any reason why we would switch back. The fact that every cam is polished, cam doctored to within tenths of a degree and the huge selection of 8620 cores is something Comp just can't compete with.
Old Jul 31, 2015 | 01:39 PM
  #40
Jimbo1367's Avatar
I say put the TFS head on one bank and the PRC on the other and see what side runs better.
