MMS 220 Build for "Ghost Hawk"
I figure the oil drain holes are big enough for pressure to equalize. GZ just uses the oil fill cap
I ran mine to a 10an fitting in the rear of both my valve covers and y'd it into the pump. Worked great.
On bigger power cars using the pro pump GZ actually just recommends using a 12an line from the passenger side valve cover but I just didn't like the idea of it so ran a 10an to each valve cover. I set it up on both my cars, one has a pro pump and one has a sportsman pump like Darth.
What does your fuel system consist of?
