How clean should my heads be?
Old Jul 21, 2015 | 06:35 AM
go blue 22's Avatar
Default How clean should my heads be?
I am rebuilding my 01 LS6 after a failed #7 piston. How dirty do my heads and valves look? Should I have a brass wire wheel and clean every valve until it is carbon free? Combustion chamber? Exhaust ports? Thanks in advance.
Attached Thumbnails How clean should my heads be?-photo922.jpg   How clean should my heads be?-photo4294967291.jpg   How clean should my heads be?-photo4294967286.jpg   How clean should my heads be?-photo88.jpg   How clean should my heads be?-photo663.jpg
Old Jul 21, 2015 | 07:36 AM
ICRAZY6's Avatar
They don't look bad. But I would say go ahead and clean everything up. Why not, it's all apart.
Old Jul 21, 2015 | 08:31 AM
A.R. Shale Targa's Avatar
A wire wheel bench grinder works great to get all the carbon off the valves. Take a cartridge sanding roll to the bowls to blend the seats and casting flash before lapping the valves in. Also a coarse red scotch brite pad makes the valve stems look new again, especially when cleaning them in a parts solvent tank
